NetTopologySuite IComparer Exception - Unable to Sort
When attempting to edit a Field boundary layer our application is generating a NetTopologySuite IComparer exception executing EditOverLay.CalculateAllControlPoints method.  Any idea what may be causing this error based on the below Process Description, Code Snippet, and Exception error information.
Application build target framework is .NET 4.5.2.
MapSuite Desktop Edition 8.0.0.351
Process
Process starts with clicking within a boundary layer displayed on the map
A) Determine screen point based on clicked map position
B) Load all field boundary layers into InMemoryFeatureLayer (can be multiple field layers)
C) Determine if screen point is within one of the feature layers
D) If point resides in feature layer,  load feature into EditShapesLayer and calculate all points
Code Snipet
        Dim lol As LayerOverlay = Nothing
        Dim lay As InMemoryFeatureLayer = Nothing
        Static bBusy As Boolean = False
        Dim screenPoint As PointShape = Nothing
        Dim polyShape As BaseShape = Nothing
        Dim feat As Feature = Nothing
        Dim clickArea As MultipolygonShape = Nothing
        Dim bFound As Boolean = False
        Dim i As Int16 = 0
        Try
            If Not skipCheck Then
                If gMap.TrackOverlay.TrackShapeLayer.IsVisible Or gMap.EditOverlay.EditShapesLayer.IsVisible Then
                    Exit Sub
                End If
            End If
            If bBusy Then
                Exit Sub
            End If
            bBusy = True
’A) *** Determine screen point based on map position
            lol = gMap.Overlays.Item(K_MAPPING_OVERLAY_ELE)
            screenPoint = New PointShape(e.WorldX, e.WorldY)
            Select Case sTrackMode
                Case K_FIELD() + K_EDIT(), K_CROPZONE() + K_EDIT()
                    tsCmdOk.Enabled = False
’B) *** Load all field layers into  InMemoryFeatureLayer
                    If sTrackMode = K_FIELD() + K_EDIT() Then
                        lay = lol.Layers.Item(K_FIELDS_ELE_LC)
                    Else
                        lay = lol.Layers.Item(K_CROPZONES_ELE_LC)
                    End If
’C) *** For each feature layer check for clicked point within boundary
                    For Each feat In lay.InternalFeatures
                        If TypeName(feat.GetShape()) = “PolygonShape” Or TypeName(feat.GetShape()) = “MultipolygonShape” Then
                            polyShape = feat.GetShape()
                            If Not IsNothing(polyShape) Then
                                If polyShape.Contains(screenPoint) Then
’D) *** Point found within boundary.  Load into EditShapesLayer and calculate all points
                                    gMap.EditOverlay.EditShapesLayer.InternalFeatures.Add(“EDITING”, feat)
                                    gMap.EditOverlay.CalculateAllControlPoints()
                                    gMap.EditOverlay.CanAddVertex = True
                                    gMap.EditOverlay.CanRemoveVertex = True
                                    sTrackMode = sTrackMode + K_END_UC()
                                    workFeat = feat
                                    gMap.EditOverlay.EditShapesLayer.IsVisible = True
                                    tsCmdOk.Enabled = True
                                    Exit For
                                End If
                            End If
                        End If
                    Next
Exception Error
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.ArgumentException: Unable to sort because the IComparer.Compare() method returns inconsistent results. Either a value does not compare equal to itself, or one value repeatedly compared to another value yields different results. IComparer: ‘GisSharpBlog.NetTopologySuite.Index.Strtree.STRtree+AnonymousXComparerImpl’.
   at System.Array.SorterObjectArray.DepthLimitedQuickSort(Int32 left, Int32 right, Int32 depthLimit)
   at System.Array.Sort(Array keys, Array items, Int32 index, Int32 length, IComparer comparer)
   at System.Collections.ArrayList.Sort(Int32 index, Int32 count, IComparer comparer)
   at System.Collections.ArrayList.Sort(IComparer comparer)
   at GisSharpBlog.NetTopologySuite.Index.Strtree.STRtree.CreateParentBoundables(IList childBoundables, Int32 newLevel)
   at GisSharpBlog.NetTopologySuite.Index.Strtree.AbstractSTRtree.CreateHigherLevels(IList boundablesOfALevel, Int32 level)
   at GisSharpBlog.NetTopologySuite.Index.Strtree.AbstractSTRtree.Build()
   at ThinkGeo.MapSuite.Core.InMemoryFeatureSource.BuildIndex()
   at ThinkGeo.MapSuite.Core.InMemoryFeatureLayer.BuildIndex()
   at ThinkGeo.MapSuite.DesktopEdition.EditInteractiveOverlay.CalculateVertexControlPoints()
   at ThinkGeo.MapSuite.DesktopEdition.EditInteractiveOverlay.CalculateAllControlPoints()
   at AGRIS.Agy.AgyMapping.ucMapping.gMap_MapClick(Object sender, MapClickWinformsMapEventArgs e)
   at ThinkGeo.MapSuite.DesktopEdition.WinformsMap.OnMapClick(MapClickWinformsMapEventArgs e)
   at ThinkGeo.MapSuite.DesktopEdition.WinformsMap.5xM=(InteractionArguments iBc=)
   at ThinkGeo.MapSuite.DesktopEdition.WinformsMap.0hM=(Object dhc=, 0xU= dxc=)
   at ThinkGeo.MapSuite.DesktopEdition.MouseEventAnalyzer.OnMouseEvent(0xU= e)
   at ThinkGeo.MapSuite.DesktopEdition.MouseEventAnalyzer.txQ=(Double uBQ=, Double uRQ=, Double uhQ=, Double uxQ=)
   at ThinkGeo.MapSuite.DesktopEdition.WinformsMap.fBc=(Object fRc=, MouseEventArgs fhc=)
   at System.Windows.Forms.MouseEventHandler.Invoke(Object sender, MouseEventArgs e)
   at System.Windows.Forms.Control.OnMouseMove(MouseEventArgs e)
   at System.Windows.Forms.Control.WmMouseMove(Message& m)
   at System.Windows.Forms.Control.WndProc(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
    Assembly Version: 4.0.0.0
    Win32 Version: 4.0.30319.34209 built by: FX452RTMGDR
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
AGRIS.Agy.AgyMenuGUI
    Assembly Version: 1.0.6001.25000
    Win32 Version: 1.0
    CodeBase: file:///C:/APPS/AGRIS/Bin/AGRIS.Agy.AgyMenuGUI.DLL
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System
    Win32 Version: 4.0.30319.34239 built by: FX452RTMGDR
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
Microsoft.VisualBasic
    Assembly Version: 10.0.0.0
    Win32 Version: 12.0.20806.33440 built by: FX45W81RTMREL
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
System.Core
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
AGRIS.Agy.AgyGlobal
    Assembly Version: 1.0.6000.25001
    Win32 Version: 1.0
    CodeBase: file:///C:/APPS/AGRIS/Bin/AGRIS.Agy.AgyGlobal.DLL
AGRIS.Agy.AgyUtilityObjects
    Win32 Version: 1.0
    CodeBase: file:///C:/APPS/AGRIS/Bin/AGRIS.Agy.AgyUtilityObjects.DLL
AGRIS.Agy.AgyUtilityScreens
    Win32 Version: 1.0
    CodeBase: file:///C:/APPS/AGRIS/Bin/AGRIS.Agy.AgyUtilityScreens.DLL
System.Xml
    Win32 Version: 4.0.30319.34230 built by: FX452RTMGDR
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
AGRIS.Agy.AgyUserControls
    Win32 Version: 1.0
    CodeBase: file:///C:/APPS/AGRIS/Bin/AGRIS.Agy.AgyUserControls.DLL
    Win32 Version: 1.0
    CodeBase: file:///C:/APPS/AGRIS/Bin/AGRIS.Agy.AgyMapping.DLL
Microsoft.VisualBasic.PowerPacks.Vs
    Win32 Version: 11.0.50727.1
    CodeBase: file:///C:/APPS/AGRIS/Bin/Microsoft.VisualBasic.PowerPacks.Vs.DLL
MapSuiteCore
    Assembly Version: 8.0.0.0
    Win32 Version: 8.0.0.351
    CodeBase: file:///C:/APPS/AGRIS/Bin/MapSuiteCore.DLL
DesktopEdition
    CodeBase: file:///C:/APPS/AGRIS/Bin/DesktopEdition.DLL
NetTopologySuite
    Assembly Version: 1.7.3.31740
    Win32 Version: 1.7.3.31740
    CodeBase: file:///C:/APPS/AGRIS/Bin/NetTopologySuite.DLL
System.Configuration
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
Accessibility
    Win32 Version: 4.0.30319.33440 built by: FX45W81RTMREL
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
CustomMarshalers
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_32/CustomMarshalers/v4.0_4.0.0.0__b03f5f7f11d50a3a/CustomMarshalers.dll
GeoAPI
    Assembly Version: 1.1.0.0
    Win32 Version: 1.1.0.0
    CodeBase: file:///C:/APPS/AGRIS/Bin/GeoAPI.DLL
Microsoft.mshtml
    Assembly Version: 7.0.3300.0
    Win32 Version: 7.0.3300.0
    CodeBase: file:///C:/Windows/assembly/GAC/Microsoft.mshtml/7.0.3300.0__b03f5f7f11d50a3a/Microsoft.mshtml.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
    <system.windows.forms jitDebugging=“true” />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
Hi Rudolph,
We noticed you opened ticket on the same issue in out ticket system, so we will reply it in the ticket. But I will update here if solved in case others meet the same issue.
