New DLL Problem
Dear James,
As per your sugession (To Implement Copy FeatureLayer and TrackZoom), I have changes my old DLL (4.5.0.0) to new DLL (4.5.157.0). It working for new required changes, but it gives problem in my old code.
At one place I have showed my column value of map. its working for old dll but throw exception in new dll.
The code is  as below:
Dim CustomTextStyle As TextStyle = New TextStyle
Dim colName As String = drpField.Text.Trim   'The column name of map
System.Windows.Forms.Cursor.Current = Cursors.WaitCursor
Application.DoEvents()
Dim Layer As FeatureLayer = WinformsMap1.FindFeatureLayer("WorldLayer")
CustomTextStyle = TextStyles.CreateSimpleTextStyle(colName, "Arial", 7, DrawingFontStyles.Bold, GeoColor.FromArgb(255, 91, 91, 91))
CustomTextStyle.PointPlacement = PointPlacement.Center
CustomTextStyle.OverlappingRule = LabelOverlappingRule.NoOverlapping
CustomTextStyle.DuplicateRule = LabelDuplicateRule.UnlimitedDuplicateLabels
Layer.ZoomLevelSet.ZoomLevel01.CustomStyles.Add(CustomTextStyle)Layer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20
WinformsMap1.Refresh()
System.Windows.Forms.Cursor.Current = Cursors.Default
It was running earlier, but now it throw exception like
ArgumentOutOfRangeException was unhandled. Index was out of range. Must be non-negative and less than the size of collection. Parameter Name:index
Please see the problem.
If you want to complete code, please tell me.
Regards
Sanjay
Hi Sanjay,
 We have tested the code you sent to us, but we can’t re-produce your issue. Could you please provide us a sample to track the root cause?
 Ivan
Ivan,
 Thanks for reply. I have attached the sample code with my ticket no 3370. Please check attached data.
 Regards
 Sanjay
Sanjay,
 Thanks for your information, we have re-created your problem properly and fixed it yet, please get the newest version from the development’s daily build and try again,
 Any more questions please let me know,
 Scott,
