I created a custom in memory feature source and layer to wrap my own layer objects from a custom spatial storage system. I have no problems displaying the layer in a map control and using styles/labels that access the attributes of the features.
But when I tried to call FeatureSource.GetFeaturesByColumnValue I get a NullReferenceException
System.NullReferenceException occurred
Message="Object reference not set to an instance of an object."
Source="MapSuiteCore"
StackTrace:
at ThinkGeo.MapSuite.Core.FeatureSource.GetFeaturesByColumnValueCore(String columnName, String columnValue)
at ThinkGeo.MapSuite.Core.FeatureSource.GetFeaturesByColumnValue(String columnName, String columnValue)
at Tcc.Expresso.UI.RecEngine.VRAExportControl.listViewPrevew_SelectionChanged(Object sender, SelectionChangedEventArgs e) in C:\TFSSource\Expresso\Tcc.Expresso.UI\RecEngine\VRAExportControl.xaml.cs:line 273
InnerException:
In my custom feature source I did provide it with the List of FeatureSourceColumn and set the attribute dictionary of each feature. I assume that I have not set something I need to, any pointer in the right direction would be great!
I've included the code for my custom Feature Source so you can see what I'm doing, I can probably put together a simple app if needed also a little later.
Brian
using System; using System.Collections.Generic; using System.Linq; using System.Text; using ThinkGeo.MapSuite.Core; using Tcc.SpatialStorage;
namespace Tcc.Gis.ThinkGeoSupport { public class TccFeatureSource : InMemoryFeatureSource { #region Construct/Initialize
public TccFeatureSource(ITccFeatureLayer layerToWrap): base(CreateFeatureSourceColumnsForITccFeatureLayer(layerToWrap)) { this.OpenedFeatureSource += new EventHandler<OpenedFeatureSourceEventArgs>(TccFeatureSource_OpenedFeatureSource); this.WrappedLayer = layerToWrap; }
public ITccFeatureLayer WrappedLayer { get; private set; }
#endregion
#region Private Methods
private void AddTccFeaturesToInMemoryFeatures() { //We need to remove any projection while we are adding features //Otherwise the lat/lon tcc feature WKB will be un-projected incorrectly var tempProjection = Projection; Projection = null;
this.BeginTransaction(); foreach( ITccFeature tccFeature in WrappedLayer.TccFeatures ) { var attributeDictionary = new Dictionary<string, string>(); foreach( ILayerColumn layerColumn in WrappedLayer.Columns ) attributeDictionary.Add(layerColumn.Name, tccFeature.GetAttribute(layerColumn).ToString());
var thinkGeoFeature = new Feature(tccFeature.WellKnownBinary, tccFeature.Index.ToString(), attributeDictionary); AddFeature(thinkGeoFeature); } this.CommitTransaction();
//Now that the transaction had been committed, we can set the projection again Projection = tempProjection; }
#endregion
#region Static Methods
public static List<FeatureSourceColumn> CreateFeatureSourceColumnsForITccFeatureLayer(ITccFeatureLayer layer) { var outlist = new List<FeatureSourceColumn>();
foreach( ILayerColumn tccColumn in layer.Columns ) outlist.Add(new FeatureSourceColumn(tccColumn.Name, tccColumn.DataType.ToString(), tccColumn.Length));
I have recreated it and this is an issue in our system, we have added it to our tracking system and it will be fixed it in the upcoming version which will be release around next week.
For now you can override GetFeaturesByColumnValueCore method to avoid this issue for now.
