NullReferenceException - Tracking Layer
I have been encountering the crash below intermittingly.  It generally occurs the first time that an item is added to the tracking layer.
Their is try/catch logic in my application, but this crash is inside MapSuite so I do not know what in my application is causing it.  And again this does not happen all the time, only once in a while.
Any words-of-wisdom would be appreciated.
Dennis
System.NullReferenceException was unhandled
  Message=Object reference not set to an instance of an object.
  Source=WpfDesktopEdition
  StackTrace:
       at ThinkGeo.MapSuite.WpfDesktopEdition.Tile.DrawException(GeoCanvas geoCanvas, Exception exception)
       at ThinkGeo.MapSuite.WpfDesktopEdition.Tile.Draw(GeoCanvas geoCanvas)
       at ThinkGeo.MapSuite.WpfDesktopEdition.Tile.vRM=(Object vhM=)
       at System.Threading.QueueUserWorkItemCallback.WaitCallback_Context(Object state)
       at System.Threading.QueueUserWorkItemCallback.System.Threading.IThreadPoolWorkItem.ExecuteWorkItem()
       at System.Threading.ThreadPoolWorkQueue.Dispatch()
       at System.Threading._ThreadPoolWaitCallback.PerformWaitCallback()
  InnerException:
Hello Dennis,
 Thanks for your post, sorry I can’t find the root cause just by this error message.
 Is that possible you can make a sample that recreate the problem? Then I debug it and find the root cause easily.
 I appreciate your help.
