Object reference not set to an instance of an object
Hi
Whenever I view the map in browser ,frequently i get the message..........
Object reference not set to an instance of an object.
Also when i click on map thid message is displayed.
how to solve this problem.Please help me.
  It could be a vast number of causes and my suspicion is that this is something in your code. We would need a sample app from you that we can run and see the problem happening to determine the exact cause of this. Could you, please, send us a sample app for that? Thank you.
bhagyashree, take a careful look into the connections. Normally this problem for me appears when I have samething wrong with my layer connection. For instance, be unable to connect to specific Oracle instance or shape file.
Thank you, Rui, for your participation.
 Bhagyashree, if you still have problems, do not hesitate to send us more info and ideally a sample app to determine the exact problem. Thank you.
