Offset LineShape?
I've tried to search the forum for this, but the forum search mechanism always puts "or" between multiple words :-(
So here goes ...
I'm looking for a routine or method to generate an offset LineShape by a distance.
Not by a fixed distance, like the TranslateByOffset() method, but a truly parallel LineShape to either side as selected.
I may be missing the obvious, but so far I've only seen the Buffer() method doing anything remotely like this, but that obviously generates too much.
Please advise.
(deleted)
Anyone ?
Lars,
 I think that you can find something that you need by adapting one of the samples in the Code Community, Offset Point at a Right Angle, wiki.thinkgeo.com/wiki/Map_Suite_We...ight_Angle. In this sample, we show how to move a point parallel to a line segment. From there, you can see how you could offset an entire line in a parallel way. Can you give a concrete example and I think we can provide you with the exact solution for your case? Thank you.
