OpenLayers.Control.LayerSwitcher Client-Side
I am trying to dynamically display/hide an imagery overlay based on the map zoomlevel.  It try the code below, it would work on IE 7 but not for other browsers. Is there another way to dynamically show/hide the overlayswitcher option on the client-side.
function ShowAerial(iZoomLevel) {
        var map = Map1.GetOpenLayersMap();
        if (map) {
            var controls = map.getControlsByClass('OpenLayers.Control.LayerSwitcher');
            if (controls[0]) {
                for (var iIndex = 0; iIndex < controls[0].layerStates.length; iIndex++) {
                    if (controls[0].baseLayers[iIndex].layer.name == 'Hybrid') {
                        controls[0].baseLayers[iIndex].inputElem.style.display = (map.getZoom() >= iZoomLevel) ? 'block' : 'none' ;
                      controls[0].baseLayers[iIndex].labelSpan.style.display = (map.getZoom() >= iZoomLevel) ? 'block' : 'None';
                        break;
Hi Ttd,
I did not change your code, but here is a way for you, please see the two lines of code which have commends. function ShowAerial(){
    if(controls.length > 0){
        var overSwitcher = controls[0];
        var layer = map.getLayer("Hybrid");
        // this property makes whether display or not in the overlay switcher.
        layer.displayInLayerSwitcher = false;
        // OpenLayers need to check the name, and Id of the layer, if it's not changed, it won't redraw
        // So here I changed the name of it to raise the redraw function.
        layer.name = "Yahoo1";
        overSwitcher.redraw();
Howard
This works!!! Thank you, I didn’t know you have to change the layer name to fire the redraw() event.
Ttd,
 That’s what I didn’t know neither before; I checked OpenLayers’ library then I just know. I think they can make the checking looser.
 Thanks for reporting and if you have any queries please let me know.
 Howard
