OpenLayers.Layer.XYZ
I have a WMS service address which is using OpenLayers.Layer.XYZ layer format. Can I use thinkgeo map suite to display it? Below is the html code of a web page that displays data from this service:
    <script type=“text/javascript” src=“http://openlayers.org/api/OpenLayers.js”></script>
    <script type=“text/javascript”>
        function init() {
            OpenLayers.Util.onImageLoadError = function () {
                this.style.display = “”; this.src = “empty.png”;
            OpenLayers.Tile.Image.useBlankTile = false;
            var options = {
                projection: new OpenLayers.Projection(“EPSG:900913”),
                displayProjection: new OpenLayers.Projection(“EPSG:4326”),
                units: “m”,
                maxResolution: 156543.0339,
                maxExtent: new OpenLayers.Bounds(-20037508.34, -20037508.34, 20037508.34, 20037508.34), numZoomLevels: 19
            map = new OpenLayers.Map(‘map’, options);
            layer = new OpenLayers.Layer.WMS(
                                                              “Map”,
                                                              “10.6.88.218:10205/tile21.ashx?z=${z}&x=${x}&y=${y}”,
        ‘attribution’: ‘’,
        numZoomLevels: 19,
        sphericalMercator: true,
        transitionEffect: ‘resize’
            map.addLayers([layer]);
            var initialLat = 5010000;
            var initialLon = 3238000; var initialZoom = 14; map.setCenter(new OpenLayers.LonLat(initialLon, initialLat), initialZoom);
    </script>
<body onload=“init();” style=“background-color: #26424b;”>&nbsp;&nbsp;&nbsp; <div id=“map” style=“height: 800px; width: auto; margin-right:0px;margin-left:0px;”>&nbsp;&nbsp;&nbsp; </body>
 line was written wrong, the correct code is:
 new OpenLayers.Layer.XYZ
Hi Bulent,
Please try the following customized Overlay, a bit simple, you can make it support more properties.
Server Side:
public class XyzOverlay : Overlay
        private string url;
        public XyzOverlay()
        public XyzOverlay(string id, string url)
            : base(id, true)
            this.Url = url;
        [JsonMember(MemberName = "url")]
        public string Url
            get { return url; }
            set { url = value; }
        [JsonMember(MemberName = "otype")]
        protected override string OverlayType
            get { return "XYZ"; }
Client Side:
<script language=<code style="color: blue;">"javascript" <code style="color: #000000;">type=<code style="color: blue;">"text/javascript"<code style="color: #000000;">>
    var OnMapCreating = function (map) {
        SphericalOverlay.prototype.createXyzOverlay = function () {
                this.options.sphericalMercator = true;
                this.element = new OpenLayers.Layer.XYZ(this.name, null, this.options);
                this.element.url = this.json.url;
        SphericalOverlay.prototype.createOverlay = function () {
            switch (this.type.toUpperCase()) {
                case "XYZ":
                    this.createXyzOverlay();
                    break;
                default:
                    break;
</script>
Hello Johnny,
Thank you for your reply. I added custom layer class to the MVC project and also added the script file to the view. Can you also provide a simple controller and view code to see the map?
Hi Bulent,
Please check the attached sample.
MvcApplication10.zip (567 KB)
Thanks for your support :)
Welcome Bulent, any questions please feel free to let us know.
I can now display a XYZ tile map with a great success but can’t restrict the extend. I only want to show a region on the web page.
By the help of Map.CurrentExtent, I can focus to the specific region but I can zoom out to the whole world. I tried setting Map.RestrictedExtent to the currentextend but still I can zoom out. How can I show only the specific region’s tiles (no zoom out)?
Hi Bulent,
Please try the code as following (NOTE: please pay attention to the TODO comments, maybe you need some changes there)
    map.isValidZoomLevel = function (zoomLevel) {
        return ((zoomLevel != null) &&
           (zoomLevel >= 9) && // set min level here, could read from property
           (zoomLevel < this.getNumZoomLevels()));
    map.maxExtent = new OpenLayers.Bounds(-13758743.4295939, 5591455.28887228, -13531302.3472101, 5757360.4178881);
            case "XYZ":
                break;
            default:
                break;
