I am trying to create a simple map using an OpenStreetMapLayer. Most times when I try to load the map, I receive an error reading "An item with the same key has already been added". The exception is unhandled and cannot be caught. The stack trace is below. I am using build 5.0.43.0.
at System.ThrowHelper.ThrowArgumentException(ExceptionResource resource)
at System.Collections.Generic.Dictionary`2.Insert(TKey key, TValue value, Boolean add)
at System.Collections.Generic.Dictionary`2.Add(TKey key, TValue value)
at ThinkGeo.MapSuite.Core.OpenStreetMapLayer.8ys=(Object 9Cs=)
at System.Threading.ThreadHelper.ThreadStart_Context(Object state)
at System.Threading.ExecutionContext.runTryCode(Object userData)
at System.Runtime.CompilerServices.RuntimeHelpers.ExecuteCodeWithGuaranteedCleanup(TryCode code, CleanupCode backoutCode, Object userData)
at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state)
at System.Threading.ThreadHelper.ThreadStart(Object obj)
Thanks in advance for your help!
