Hi
I use
var osmOverlay = new OpenStreetMapOverlay();androidMap.MapUnit = GeographyUnit.Meter;androidMap.ZoomLevelSet = new OpenStreetMapsZoomLevelSet();ManagedProj4Projection proj4 = new ManagedProj4Projection();proj4.InternalProjectionParametersString = ManagedProj4Projection.GetDecimalDegreesParametersString();proj4.ExternalProjectionParametersString = ManagedProj4Projection.GetGoogleMapParametersString();proj4.Open();androidMap.CurrentExtent = proj4.ConvertToExternalProjection(new RectangleShape(-12, 53, 18, 36)) as RectangleShape;androidMap.Overlays.Add(osmOverlay);
The current extent is ok, west europe
I try
androidMap.MapUnit = GeographyUnit.Meter;androidMap.ZoomLevelSet = new OpenStreetMapsZoomLevelSet();ManagedProj4Projection proj4 = new ManagedProj4Projection();proj4.InternalProjectionParametersString = ManagedProj4Projection.GetDecimalDegreesParametersString();proj4.ExternalProjectionParametersString = ManagedProj4Projection.GetGoogleMapParametersString();proj4.Open();androidMap.CurrentExtent = proj4.ConvertToExternalProjection(new RectangleShape(-12, 53, 18, 36)) as RectangleShape;var osmLayer = new OpenStreetMapLayer();//osmLayer.SendingWebRequest += osmLayer_SendingWebRequest;layerOverlay.Layers.Add(osmLayer);layerOverlay.TileType = TileType.MultiTile;androidMap.Overlays.Add("OSM", layerOverlay);
The extent of the map is in the south austrialia, and display the map is very slow.
I try to use OpenStreetMapLayer for sendingWebRequest event.
Regards
laurent M
