(ThinkGeo.Oracle 12.1.4)
The following code always crashes:
new OracleFeatureLayer("User ID=me;Password=secret;Data Source=server/service",
"TAB", "FID").Open();
System.NullReferenceException: Object reference not set to an instance of an object. at ThinkGeo.Core.GdalFeatureSource.OpenCore() at ThinkGeo.Core.OracleFeatureSource.OpenCore() at ThinkGeo.Core.FeatureSource.Open() at ThinkGeo.Core.FeatureLayer.OpenCore() at ThinkGeo.Core.Layer.Open() at OracleTest.MainWindow.MapViewLoaded(Object sender, RoutedEventArgs e) in MainWindow.xaml.cs:line 42
As far as I can tell, the driver does not even try to create a network connection to the server.
The same error happens with or without correct information in the connection string, or with a string that does not even look like a connection string. I took the connection string from the MapSuite 10 examples; has the syntax changed in ThinkGeo.Core 12?
