Osgb
I am just trying to get to grips with Map Suite.  I have some tif images in the OSGB coordinate system.  When I add these images to a Map it does not show up.  Do I need to tell the Map about the OSGB coordinate system?
Slicc
Hello Steven,
 Thanks for your post, I think when you say OSGB coordinate, you mean OSGB 1936 British National Grid (epsg:27700)?
 If so, yes you need let map control knows if you are using this projection working with some other projection, we have Proj4projection can let user unify the projection between different data.
 If this tif images are only data you are using, I think you can just set the map unit as meter, you don’t need change the projection, it will work.
 Please let me know if I misunderstanding something or it still not working.
