Out of memory when using ecwRaserLayer
hi, when I use ecwRaserLayer to load a ecw image  of whole china and a 20 level high resolution ecw image of Beijing.
1)at  the begining, the viewpoint locates at low resolution of china, the  memory comsumption is 100M approximately.
2)when I double cliked the map to zoom in the high resolution of Beijing, the memory consumption quickly increase to 600M.
3) but when I zoom out to the low resolution, the memory consumption do not reduce.
and as time goes on, the memory comsumption still keep in 600~700M.
what makes me trouble is that, why the map Suite do not release the memory dynamic?
then , I use the cachTile,  the same phenomenon happened.
thinks,
liu
 Hi Liu,
Thanks for  your post, would you please check the anwser at gis.thinkgeo.com/Support/Dis...fault.aspx?
Best Regards
