OverflowException while using GoogleOverlay
Trying to evaluate the Silverlight edition of MapSuite, I would like to have a simple Map with Google as background and a WmsOverlay over it.
First I'm trying to have Google and I copy the sample provided in your VS2008 C# solution.
When running, I get an OverflowException.
My config is : Windows 7 x64 French, VS 2008 Team Suite SP1...
Here is the stack trace :
Détails de l’erreur de la page Web
Agent utilisateur : Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 6.1; WOW64; Trident/4.0; GTB6.3; SLCC2; .NET CLR 2.0.50727; .NET CLR 3.5.30729; .NET CLR 3.0.30729; Media Center PC 6.0; InfoPath.2; .NET4.0C; .NET4.0E)
Horodateur : Tue, 7 Sep 2010 15:31:16 UTC
Message : Sys.InvalidOperationException: ManagedRuntimeError error #4004 in control 'SilverlightMapConnector1': System.OverflowException: L'opération arithmétique a provoqué un dépassement de capacité.
   à System.Convert.ToInt64(Double value)
   à ThinkGeo.MapSuite.SilverlightEdition.WmsOverlay.xc6f73c2fdb9eb72d(RectangleShape xb35a33b423b17f65, RectangleShape xa4ecffa39a64a039, Double x24e8814527642864, Int32 xc9855a055eb205f4, Int32 x88270fbf5293303b)
   à ThinkGeo.MapSuite.SilverlightEdition.WmsOverlay.x5f3f7df7500bf8b4(Canvas x31c084515ae9393f, RectangleShape xb35a33b423b17f65, Int32 x8c48a4dc6d63ef75, Int32 xb228ac7781d1068b, Int32 xc9855a055eb205f4, Int32 x88270fbf5293303b, Collection`1 xb309cb779aa07274)
   à ThinkGeo.MapSuite.SilverlightEdition.WmsOverlay.DrawCore(RectangleShape worldExtent)
   à ThinkGeo.MapSuite.SilverlightEdition.GoogleOverlay.DrawCore(RectangleShape worldExtent)
   à ThinkGeo.MapSuite.SilverlightEdition.GoogleOverlay.<>c__DisplayClass2.<Draw>b__0()
Ligne : 437
Caractère : 17
Code : 0
URI : mapsuite/ScriptResource.axd?...ffc3098c52
Where "mapsuite" is an host registered locally in my hosts files. TWeb site is hosted locally using IIS7.
Any idea ?
Hi, Nicolas
Thanks for your information about this problem. We have fixed this issues and it should be available in the latest Daily Build (4.0.127.0 or later). Please get it through helpdesk.thinkgeo.com/helpdesk/login.aspx.
Khalil
Thank you Khalil,
it seems that only the 4.0.126 daily build is available through the Helpdesk/ Evaluation section.
Do you plan to deliver the 4.0.127 quickly ?
Regards
Nicolas
Nicolas,
   The new versions are built daily through our automated build process.  Tomorrow the new build will be 4.0.127 and you can get the feature then.  Just check it tomorrow.
Ok, thank you very much
Nicolas,
   No problem!
