Pan
This might be a silly question, how can I disable Paning on the client-side. Currently, I am using the below code to restrict the extent. However, this require me to know bound extent. I need the extent to be dynamic.
On Client-side Load:
Sys.WebForms.PageRequestManager.getInstance().add_pageLoaded(restrictArea);
 function restrictArea() {map.setOptions({ "restrictedExtent": new OpenLayers.Bounds(CurrentMapBound.left, CurrentMapBound.top, CurrentMapBound.right, CurrentMapBound.bottom) }); }
Mark,
OpenLayers has an API to disable the panning. Here is the code.
  var OnMapCreated = function(map) {
            var navigation = map.getControlsByClass("OpenLayers.Control.Navigation")[0];
            navigation.dragPan.deactivate();
341-DisablePanningOnClient.txt (276 Bytes)
This seems to disable only panning. Is there a way to disable the "Zoom to Area" (Shift and drag boundingbox) as welll. Thanks
The following script will disable all the mouse functions, including the track zoom in.
            navigation.deactivate();
