PanMapByScreenPixel event
I am using client side calls to PanMapByScreenPixel to allow user to move around the map.
Also, I am mapping the server side event .ExtentChanged.
The ExtentChanged server side event is used to do some Marker manipulations when user zooms, problem is, I also get post backs when the user pans.
Is there a way to cancel the ExtentChanged event on user pan ?
If not, can I differentiate between pan post backs and zoom post backs ?
Thank you in advance,
Runny
Runny,
 I think this code can simply solve your problem.
 private double previousScale;
         protected void Map1_ExtentChanged(object sender, ExtentChangedEventArgs e)
             if (e.CurrentScale != previousScale)
                 // Do works
                 previousScale = e.CurrentScale;
 If zoom change the scale will change, if customer only pan, the scale won’t change.
Thanks Don,
 Just what I needed
 Runny
Runny,
 You’re welcome.
