Dear Support,
I am using MultiGeoRasterLayer object to load number of images (tif files) into one raster layer which is overlaid with another vector layer. Initially everything is rendered properly both layer overlaying squarely on each other. The problems comes when I pan the map the raster and vector layers go out of alignment. That is to say they are not exactly overlaid. Can you please give me a solution to the problem and if possible a sample code for it?
Best Regards,
Vincent
Panning Problem on MultiGeoRasterLayer
Hi Vincent,
We didn’t experience such issue before and we also try to recreate the issue by following your case but with no lucky.
We are using the attached sample to test, could you please recreate the issue and then send it to us? Also, I am wondering which version you are referring?
If necessary, some screenshots or a video is appreciate.
Waiting for your further information.
MultiGeoTiffRasterLayer.zip (1.39 MB)
