Panning/Zooming jumps back to original point
it seems that when you adding a layer in 'MultipleTile' Mode and then when you are panning around, parts of the map are rendered as your move and some tiles are starting to load and then sudenly the map jumping back to it's original position.
 in addition sometime when we zooming out very quickly it just returning back to original zoom level.
Hi Ben,
 Currenly we can’t re-produce your issue by following your description. We guess there should be some special scenarioes in your application, could you please provide us detailed information to recreate your issue?
 Ivan
Many thanks, for your answer.
 it was my problem.
Ben,
 Do you mind sharing what you found to be the cause to be?  I think I’ve been seeing the same thing (with the latest builds) but haven’t yet figured out the root cause… I’m hoping its the same.
 .Ryan.
Ryan,
 Can you provide your sample application to us so that we can re-produce your problem properly, as Ivan said maybe the problem is from some special scenarioes or your data files.
 Scott,
Hi Scott…
 My problem lies in a large system… I have tried to create a simple sample, except I did not see this issue in it… so its in something else I am doing.  I have not yet had time to track down what is causing it as deadlines loom and it works using version 129, so it isn’t super high on my priority list.  Hopefully I can get something to you guys soon.
 .Ryan.
Ryan,
 Hope everything is ok for your application, if you encounter any new problems with the map control please let us know,
 Scott,
Hi Ryan,
 When I was panning the map, other controls on my window which were showing the loading percentage and … were forcing the map to resize (Cause they need more space) and then because of map size change, it was re rendering itself therefore it was returning to start panning point.
 you may have same problem.
Ben,
 Which version did you use? If you have the exact problem can you provide a simple sample to us so that we can understand the exact problem for the WPF Desktop edition. According to my test, when I panned the map, the map size dose not change. So can you give us further information about it?
 Scott,
Hi Scott,
 I it was because on the panning time I was changing the control size.
 that was not problem of control or any specific version.
Hi Ben,
 Thank you for sharing your experience with Ryan and us. Have a good day.
 Ivan
