PanToWorldCoordinate going to incorrect location
Hi guys i am using google's api for geocode requests.
I get it in this format:
LAT: 28.055949
LONG:  -25.7153269
I use a javascript function:
    <script language="javascript" type="text/javascript">
        function PanToWorldCoordinate(x, y) {
               var newX =  x;
               var newY = y;
                Map1.PanToWorldCoordinate(newX, newY);
    </script>
Which moves the Map to a totally incorrect location.
The correct location on my ThinkGeo Map shows up as:
X Y      (3117076.2094464 , -3001274.014313)
How do i convert the Lat long to the x y ?
Thank you in advance.
Hi Gregory,
 If you are using google’s map, why not set Map1.MapUnit = GeographyUnit.Meter; ?
Hi Gregory,
 I think this topic will be helpful for you.
 gis.thinkgeo.com/Support/DiscussionForums/tabid/143/aff/12/aft/8440/afv/topic/Default.aspx
 Please see the Khalil’s post.
 Posted By Don on 08-09-2011 01:10 PM
Hi Gregory,
I have   Map1.MapUnit = GeographyUnit.Meter already
i will try the function khalil posted.
I tried it but have no luck.
 HEre is my function
      <script language=“javascript” type=“text/javascript”>
            var point = new OpenLayers.Geometry.Point(x, y);
            var srcProj = new OpenLayers.Projection(‘EPSG:900913’);
            var desProj = new OpenLayers.Projection(‘EPSG:4326’);
            var newPoint = OpenLayers.Projection.transform(point, srcProj, desProj);
            var newX = newpoint.x;
            var newY = newpoint.y;
    </script>
I had similar problem some time ago. I verified at the time that the OpenLayers Map object was not having it's Projection setted to EPSG900913, I had to make it by hand, for that I inherited Map Control and added another property Projection.
public class MapControl : ThinkGeo.MapSuite.WebEdition.Map     {
[JsonMember(MemberName = "projection")]
public string Projection { get; set; }
And then made some prototyping to MapParser
 mapParser.prototype.onMapCreating = function (map) {
this.map.projection = this.json.projection;
I guess something is missing on Thinkgeo (or was missing at the time.)
so in you case I would suggest to set the Projection prior to doing your stuff. Something like Map1.GetOpenLayersMap().projection="EPSG:900913"
I also notice that you should confirm the srcProj and destProj variables.
 srcProj = "EPSG:4326"
 destProj="EPSG:900913"
I get the Values from the GEO Code from this link:
maps.google.com/maps/geo?q=botswana&output=xml&key=ABQIAAAA1KPQi4YfHGdBrxrD7xfk3BShg55qzDjUncDQtZWMkgWc-6jGwhTE2_EhbB-MTW6vtSxa--SpoABjPA
I get a KML / XML Response:
screencast.com/t/sFDsSkC8R
I then put the Coordinates in...
I dont know what to do with the "0" in [<coordinates>24.6848660,-22.3284740,0</coordinates>]
I actually dont know the projection
I researched it and only found a DATUM(WGS84) im not sure if thats the same as a projection:
Location Object
Name  Description
latitude  Current latitude in degrees (WGS84 datum).
longitude  Current longitude in degrees (WGS84 datum).
[24.6848660,-22.3284740,0]  0 -> Z
 This are in EPSG:4326
 So if you have your map with google as base layer in your code I think their are in an opposite order.
[b]
 var desProj  = new OpenLayers.Projection(‘EPSG:900913’);
            var srcProj  = new OpenLayers.Projection(‘EPSG:4326’);
 [/b]
But how do i get the X y Values once converted ?
IT WORKS thank you so much guys!!!
 Needed CAPS on "newPoint"
 [SOLVED]
Rui,
 Thanks for your reply!
