Hi ThinkGeo Team
I have given all appropriate access rights to ASP.Net in my machine's IIS but when I try to send a map to pdf at first it does not respond at all. When I repeat the process, it fires an exception saying "The process cannot access the file 'C:\WINDOWS\system32\MapSuite PDF Map.pdf' because it is being used by another process."
But when I do the above process right from visual studio, everything goes well. Can you give me a workaround to this problem?
Best Regards,
Vincent
