PDF-GeoCanvas Issues
Hello ThinkGeo-Team,
in our current version we print the Map by using PdfGeoCanvas. For printing we use your code suggestion where we loop through all overlays and layers and draw them on the PdfGeoCanvas.
At the moment we have 2 problems:
1,) If we compare the created pdf-document with map view we can see that raster based layers have an offset (see attached document).
Map-Control:
PDF-Dokument:
2,) If we try to print feature-layers by using an custom style where we use SquareAnchor-Type as DashCap we get an Error (see attached document).
Any suggestions to solve this problems?
Thomas
Thomas,
 I can not recreate your problem by using our HowDoI sample "UsePdfExtension", could you test it by using your data? Which version of MapSuiteCore do you use?
 I will also create a custom style and try to recreate the exception, DashCap is a property of GeoPen, so the custom style should contains a pen, right?
Hello James,
1.) I have attached a small sample application where you can see my problem.
2.) Sorry I was not clear enough.  I get the exception when I set StartCap property of GeoPen-Class to DrawingLineCap.SquareAnchor.
Thomas
PDFPrint.zip (55.3 KB)
Thomas,
Thanks for the sample, to solve this problem, you may need to use the newest version of DesktopEdition.dll and MapSuiteCore.dll, I have tested version 4.5.66.0 which works properly, you can download them from custom portal.
The PdfExtension doesn't support SquareAnchor of LineCap, so it throws NotSupportedException, it only supports Round, Square and Flat, we have updated the error message to let it more meaningful.
James,
thanks for Info. I have to mention that users can define their own styles in our GIS-Application. The user can set all style parameter  the ThinkGeo classes support. This mean they can create new styles and use in Map but they can not print (convert) it  to pdf because PdfExtension is limited.
I do not know how many limitations there are. But if there are many - I have to think about another printing solution. As I know there are printing solution with PrinterGeoCanvas-Class or GDIPlusGeoCanvas.
Can you help by pointing me in the right direction?
Thomas
Thomas,
Yes, there probably are many limitations for PdfGeoCanvas, such as LineCap, LineJoin, DrawingQuality, only allows SolidBrush etc.
The printing solution with PrinterGeoCanvas you can look at the sample I attched below.
The printing solution with GdiPlusGeoCanvas is a little bit complex, first you render the map on a bitmap, and then print a bitmap by using API.
Let me know if you have questions.
PrinterGeoCanvas.zip (30.9 KB)
Blocked AD
Hi Evan,
 Thanks to visit our forum, any question please let us know.
