Alright, next problem with the PDF Extension.
I have a map that has imagery in a custom MrSidRaster Layer. The layer is based on the code provided by ThinkgGeo in the webinar in may. I customized it only slightly, but the underlying logic is the same. The problem I'm having is that the pdf is only showing the image that was visible on the map and not the bordering tiles due the the extent change for the output to PDF.
If you want an image to see what I'm saying look at my attachment in PDFSharp Extension Issues 2. Where is have the red square is where my image is being drawn, otherwise non of the boredering tiles are apearing at all.
