i have used sample method simplemarker overlayer. but it doesnot give the desired result. i want to add two point on shapefile by clicking on it and when it clicked its world coordinates saved in variable.
Hi Sarah,
Can you clearify your requirements a bit, as far as i guessed, the anwser can be checked at gis.thinkgeo.com/Support/Dis...fault.aspx.
Any questions or problems please let us know.
Also, please use InMemoryMarkerOverlay instead, seems like there is a bug in SimpleMarkerOverlay, we are still working on it.
kindly tell me where i am wrong i used this way to get points and its coordinates. but when i assigned this user1 to routing layer startpoint like this
routingLayer.StartPoint = user1;
routingLayer.EndPoint = user2;
it gives error of null point. as i debug my code an see that user1 and user2 has coordinates but it cannot assigned to startpoint and end point
InMemoryFeatureLayer points = (InMemoryFeatureLayer)winformsMap1.FindFeatureLayer("points");
// RoutingLayer routingLayer = (RoutingLayer)winformsMap1.FindFeatureLayer("RoutingLayer");
PointShape point = new PointShape(e.WorldX, e.WorldY);
Feature p = new Feature(point.GetWellKnownBinary(), "position");
points.FeatureSource.BeginTransaction();
if (!points.InternalFeatures.Contains("position"))
points.FeatureSource.AddFeature(new PointShape( p.WellKnownBinary));
if(user1== null)
user1 = new PointShape(p.WellKnownBinary);
else if(user2 == null)
user2 = new PointShape(p.WellKnownBinary);
Sarah,
Seems nohing wrong in your code, maybe there are some issues in other places. Can you please provide us a simple sample instead of code snippet to recreate your issue?
Edgar
may i send you my whole code because still i cannot figure out my problem. give me any email id
Hello Sarah,
You can send to forumsupport@thinkgeo.com.
i have send my code on the given address Gray
Hello forum,
Did you check my code? i have send on the given address
sarah
Hello Sarah,
Thanks for your code, we got it and we are working on it, once we have a solution, we will post here asap.
Sorry for the inconvenience.
Thanks Gray i am really waiting for the solution
Hi Sarah,
You need to change your method to this:
private void winformsMap1_MapClick(object sender, MapClickWinformsMapEventArgs e)
RoutingLayer routingLayer = (RoutingLayer)((LayerOverlay)winformsMap1.Overlays["RoutingOverlay"]).Layers["RoutingLayer"];
points.InternalFeatures.Add(p);
if (user1 == null)
user1 = point;
else if (user2 == null)
user2 = point;
else
goal = new PointShape(p.WellKnownBinary);
points.FeatureSource.CommitTransaction();
winformsMap1.Refresh();
Edgar
Thanks a bundle edgar
Sarah,
You're welcome, please feel free to let us know your problem.
Edgar
