My mistake. My connection string was pointed to the wrong database.
I'm currently using the evaluation version that I downloaded today (MapSuiteCore:3.1.235;DesktopEdition:3.0.415).
I'm trying to access data from a PostgreSQL table. If I run the following code, I get an NpgsqlException: ERROR: 42P01: relation "g101_roads" does not exist
PostgreSqlFeatureSource featureSource = new PostgreSqlFeatureSource( Program.Settings.ConnectionString, "g101_roads", "id" );
featureSource.ExecutingSqlStatement += new EventHandler<executingsqlstatementpostgresqlfeaturesourceeventargs>( featureSource_ExecutingSqlStatement );
featureSource.Open();
RectangleShape boundingBox = featureSource.GetBoundingBox();
I'm using PostgreSqlFeatureSource as opposed to PostgreSqlFeatureLayer because it supports the ExecutingSqlStatement event which I used to see what query is actually going to the server.
For featureSource.Open(): select f_geometry_column,srid from geometry_columns where f_table_name='g101_roads'
This works fine and if I look at featureSource.Srid, I see 4326 which is correct.
For featureSource.GetBoundingBox(): SELECT asbinary(ST_EXTENT("imp_geometry")) FROM "g101_roads";
This does not work, resulting in the exception above. If I run this statement directly in my database browser it works fine and returns the extent I expect.
Any ideas?
Chris
