Plotting GPS data with Google Map
I am using Map Suite 5 desktop edition with VS 2010. Here I am using GoogleMapsOverlay as background map and the map loaded successfully. I have GPS Lat Long stored in sql server 2005 database. Here I am picking all Lat Long from my database and putted into InmemeoryFeatureLayer. All InmemeoryFeatureLayer are putted into a GroupLayer. The projection of InmemeoryFeatureLayer set accordingly and all data shows on my google map on proper route.
Now the Problem is when I am trying to zoom In/Out either with Mouse Left button double click/ Right button double click, the maps zooming in In/Out mode, but the route plotted with InmemeoryFeatureLayer not alligning with google map properly. What is the reason for this beahaviour I am not clear about it. Please help
To Show Google Map I am using following code
WinformsMap1.MapUnit = GeographyUnit.Meter
CurrentGeographicalUnit = setGeographicalUnit(WinformsMap1.MapUnit)
Dim googleMapLayer As GoogleMapsOverlay = New GoogleMapsOverlay()
googleMapLayer.MapType = GoogleMapsMapType.RoadMap
WinformsMap1.Overlays.Add("googleOverlay", googleMapLayer)
WinformsMap1.Overlays.MoveToBottom(WinformsMap1.Overlays.IndexOf(googleMapLayer))
Application.DoEvents()
G_GoogleLayerSelected = True
mnuSetGoogleMap.Text = "Remove Google Map"
WinformsMap1.ZoomLevelSnapping = ZoomLevelSnappingMode.None
WinformsMap1.ZoomToScale(WinformsMap1.ZoomLevelSet.ZoomLevel10.Scale)
Dim centerLatLong As Vertex
Dim xLat As Double = 28.633048
Dim xLong As Double = 77.219639
centerLatLong = GetLatLongInMeter(xLat, xLong)
WinformsMap1.CenterAt(New PointShape(centerLatLong))
To show my GPS data I am using following code
cmd.Connection = SqlCon
cmd.CommandText = "Select * from GPSData where DeviceID='" & DeviceID & "' and RecDate>='" & RecDateFrom & "' and RecDate<='" & RecDateTo & "'"
daDriveData.SelectCommand = cmd
daDriveData.Fill(dsDriveData)
If dsDriveData.Tables(0).Rows.Count > 0 Then
    Dim pointLayer As InMemoryFeatureLayer = New InMemoryFeatureLayer()
    pointLayer.Name = "PLayer1"
    ExplorerHelper.SetStylebyWellKnownTypeForMemoryLayer(pointLayer)
    pointLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20
    pointLayer.DrawingQuality = DrawingQuality.CanvasSettings
    Dim SiteLayer As GroupLayer = New GroupLayer
    SiteLayer.Name = "GRPLayer1"
    SiteLayer.Layers.Add("pointFeatureLayer", pointLayer)
    WinformsMap1.Overlays("layerOverlay").Lock.EnterWriteLock()
    Try
       DirectCast(WinformsMap1.Overlays("layerOverlay"), LayerOverlay).Layers.Add(SiteLayer.Name, SiteLayer)
    Finally
       WinformsMap1.Overlays("layerOverlay").Lock.ExitWriteLock()
    End Try
    pointLayer.Open()
    For i = 0 To dsDriveData.Tables(0).Columns.Count - 1
       pointLayer.Columns.Add(New FeatureSourceColumn("" &                     dsDriveData.Tables(0).Columns(i).ColumnName.ToString &             ""))
    Next
    pointLayer.Close()
    ReDim Preserve PointShapeForSite(dsDriveData.Tables(0).Rows.Count - 1)
    For i = 0 To dsDriveData.Tables(0).Rows.Count - 1
       If IsNumeric(dsDriveData.Tables(0).Rows(i)("LAT")) = True And                                            IsNumeric(dsDriveData.Tables(0).Rows(i)("LNG")) = True Then
         SiteLongitude = CType(dsDriveData.Tables(0).Rows(i)("LAT"), Double)
         SiteLatitude = CType(dsDriveData.Tables(0).Rows(i)("LNG"), Double)
         PointShapeForSite(i) = New PointShape(SiteLatitude, SiteLongitude)
         PointName = "P" & i.ToString
         PointShapeForSite(i).Id = "p" & i.ToString
         pointLayer.InternalFeatures.Add(PointName, New Feature(PointShapeForSite(i)))
         pointFeature = pointLayer.InternalFeatures(PointName)
         For y = 0 To dsDriveData.Tables(0).Columns.Count - 1
            pointFeature.ColumnValues.Add("" & dsDriveData.Tables(0).Columns(y).ColumnName & "",                              dsDriveData.Tables(0).Rows(i)("" & dsDriveData.Tables(0).Columns(y).ColumnName & ""))
         Next
       End If
    Next
    '----------------Set Projection
    centerLatLong = SetProjectionForInmemoryLayer(pointLayer)
    WinformsMap1.Refresh()
 End If
To Set Projection I have used following code
Public Function SetProjectionForInmemoryLayer(ByVal layer As InMemoryFeatureLayer) As Vertex
        Dim boundingBox As RectangleShape = Nothing
        Process.GetCurrentProcess().ProcessorAffinity = CType(1, System.IntPtr)
        layer.FeatureSource.Projection = Nothing
        If layer.HasBoundingBox Then
            If Not layer.IsOpen Then
                layer.Open()
            End If
            If boundingBox Is Nothing Then
                boundingBox = layer.GetBoundingBox()
            Else
                boundingBox.ExpandToInclude(layer.GetBoundingBox())
            End If
            layer.Close()
        End If
        Dim boxArea As String = boundingBox.ToString
        Dim bArea() As String = Split(boxArea, ",")
        Dim xLatCor As Double
        Dim yLongCor As Double
        If CDbl(bArea(0)) <> 0 Then
            xLatCor = CDbl(bArea(0))
            If xLatCor < 0 Then
                xLatCor = CDbl(bArea(2))
            End If
        Else
        End If
        If CDbl(bArea(1)) <> 0 Then
            yLongCor = CDbl(bArea(1))
            If yLongCor < 0 Then
                yLongCor = CDbl(bArea(3))
            End If
        Else
        End If
        Dim decimalDegreevalue As Vertex
        If Math.Abs(xLatCor) > -180 And Math.Abs(xLatCor) < 180 Then
            'This is decimal degree map
            If G_GoogleLayerSelected = True Then
                Dim proj4 As ManagedProj4Projection = New ManagedProj4Projection()
                'proj4.InternalProjectionParametersString = ManagedProj4Projection.GetWgs84ParametersString
                proj4.InternalProjectionParametersString = Proj4Projection.GetDecimalDegreesParametersString
                proj4.ExternalProjectionParametersString = Proj4Projection.GetGoogleMapParametersString()
                layer.FeatureSource.Projection = proj4
                proj4.Open()
                decimalDegreevalue = proj4.ConvertToExternalProjection(CDbl(bArea(0)), CDbl(bArea(3)))
                proj4.Close()
            Else
                decimalDegreevalue = New Vertex(CDbl(bArea(0)), CDbl(bArea(3)))
            End If
        Else
            'This is meter map
            proj4.InternalProjectionParametersString = ManagedProj4Projection.GetEpsgParametersString(32643)
            proj4.ExternalProjectionParametersString = ManagedProj4Projection.GetEpsgParametersString(4326)
            proj4.Open()
            decimalDegreevalue = proj4.ConvertToInternalProjection(CDbl(bArea(0)), CDbl(bArea(3)))
            proj4.Close()
        End If
        layer.DrawingQuality = DrawingQuality.CanvasSettings
        Return decimalDegreevalue
    End Function
Hi Sanjay,
 Could you please check your data or send it to us to see if it’s not accurate? Maybe the data is not correct. Also I noticed you mentioned you are using MapSuite 5, could you please use the 6.0 version to see the offset is still there?
 Edgar
Thanks for reply,
Data is correct, because when I am using these data with TabFeatureLayer (with .TAB file), its working properly. The problem comes when I am using GoogleMapsOverlay. In this case also the first loading of data seems ok, and after the zoom in/out, its not on the position, where it should be as I shown in attached file. How I send data to you, as I have told earlier, the data is stored in sql server 2005 database.
The version I am using is 5.0.119.0. Since the service agreement is not continued, thats why I am using our last version
Sanjay
Hi Sanjay,
 Looks like you are using one of the Development Builds, Perhaps the easiest option would be for you to download the Map Suite Desktop Evaluation Edition 6.0 from the Free Trial Downloads section of this site. You could then reference these dlls as I do see there were some changes to the 5.5 version to resolve issues with the GoogleMapsOverlay not lining up correctly. However without a software assurance plan in place we cannot supply a set of Full Edition 5.5 dlls. If you would like to renew your software assurance please feel free to contact your sales representative.
