Hi
We have been testing we have run into an issue. Is the way that the rotation transform is applied to a point style correct (i.e. myPoint.Rotation=45;) When we apply that as a rotation the point would rotate at its upper left corner. Since it is in fact representing a point on the map we were thinking that it should rotate about the center of the point (assuming that the point that it represents would be under the center of the object. Anyway if you could fill me in on what the thinking was for the rotation on the point, that would be great.
John
