Polygon InnerRings
I'm having a very frustrating problem and i was wondering if you could help?
What i want to do is select an outline area on the tracking layer and then check if within that area on a seperate layer features exist. If they do i then want to remove the equivilent space in the drawn polygon on the tracking layer.
The best way i could figure to do this was by using inner rings on the polygonshape.
i've tried to recreate functionality from the inner ring container example project to do this but it's not having the desired effect.
when the map draws the items it adds the area style to all of the elements of the polygonshape and not just the main outer ring?
I have the function remove tanks which is run
 Friend Function RemoveTanks(ByVal Dike As AreaBaseShape) As AreaBaseShape
        Dim layerOverLay As LayerOverlay = Me.UiEmergencyManagerMap1.Overlays(Overlays.TanksOverlay)
        Dim GhostTanksLayer As InMemoryFeatureLayer
        Dim DikeExtent As RectangleShape
        Dim selectedFeatures As System.Collections.ObjectModel.Collection(Of Feature)
        Dim Polygonshape As New PolygonShape(Dike.GetWellKnownBinary)
        GhostTanksLayer = layerOverLay.Layers.Item("Layer_GhostTanks")
        GhostTanksLayer.Open()
        DikeExtent = Dike.GetBoundingBox
        selectedFeatures = GhostTanksLayer.QueryTools.GetFeaturesInsideBoundingBox(DikeExtent, ReturningColumnsType.AllColumns)
        GhostTanksLayer.Close()
        Polygonshape.OuterRing = New RingShape(Dike.GetWellKnownBinary)
        If selectedFeatures.Count > 0 Then
            For Each feature As Feature In selectedFeatures
                Dim bShape As BaseShape = feature.GetShape
                If TypeOf bShape Is AreaBaseShape Then
                    Dim ringShape As New RingShape(bShape.GetWellKnownBinary)
                    Polygonshape.InnerRings.Add(ringShape)
                End If
            Next
        End If
        _LastDrawn = Polygonshape
        Return Polygonshape
    End Function
and then the commit tracking method is called
Friend Sub CommitTracking(ByVal ShapeId As String)
        Dim ShapeFeatureLayer As New InMemoryFeatureLayer
        Dim ShapesOverLay As LayerOverlay
        'add the hose to the hose layer and the shapes to the shapes layer
        ShapesOverLay = GetOverlayForType(_mapMode)
        'add the layer to the overlay
        ShapesOverLay.Layers.Add("Layer_" & _LastDrawn.Id, ShapeFeatureLayer)
            ShapeFeatureLayer.ZoomLevelSet.ZoomLevel01.DefaultAreaStyle = _CurrentAreaStyle
            ShapeFeatureLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20
        ShapeFeatureLayer.Open()
        'add it to the circle feature layer
        ShapeFeatureLayer.EditTools.BeginTransaction()
        ShapeFeatureLayer.EditTools.Add(New Feature(_LastDrawn))
        ShapeFeatureLayer.EditTools.CommitTransaction()
        ShapeFeatureLayer.Close()
        'delete off the track layer
        If Me.UiEmergencyManagerMap1.TrackOverlay.TrackShapeLayer.IsOpen Then
            Me.UiEmergencyManagerMap1.TrackOverlay.TrackShapeLayer.EditTools.BeginTransaction()
            Me.UiEmergencyManagerMap1.TrackOverlay.TrackShapeLayer.EditTools.Delete(ShapeId)
            Me.UiEmergencyManagerMap1.TrackOverlay.TrackShapeLayer.EditTools.CommitTransaction()
        End If
    End Sub
Could you please tell me why the style is being applied to the inner rings aswell as the outer and how i can avoid this?
Also is this the best way for me to perform this task or is there an easier way to remove sections of space from a polygon.
thanks
Aaron
To create an polygon with inner rings based on other polygons, the most efficient and most robust method is to use the GetDifference function of the main polygon. You simply use the resulting MultipolygonShape to display. I look at some of your code and I think that it is way too complicated than it should be if I understand well your requirements. Tomorrow, we will publish a Code Community project showing that technique and you will see exactly how this is done. In the meantime, I hope that this general advise will help you to move on.
Thanks for the reply, an example project would be fantastic.
Please, check out the new Code Community project Create Inner Ring, code.thinkgeo.com/projects/show/createinnerring. I think this will answer what you are looking for.
Also, in relation to inner rings, there is another project, Inner Ring Containment, that shows how to know if a point is inside the polygon, inside an inner ring or completely outside, code.thinkgeo.com/projects/show/innerringcontainment. You might be interested in that. Thank you.
Val,
 This is an excellent example project and one that i’m sure will help many, it certainly solved my problem so thanks very much :)
 Aaron
Aaron,
  You are welcome. Let us know if you have any other doubts/questions/comments. We are always happy to help.
 Val.
