Hi
I have noticed an issue when labeling using a textstyle.
The rendering of the page after moving around cuts off the text.
I am using the following style code
List<AssayAnalyteColourRange> colors = _colourRanges.OrderBy(i => i.Low).ToList();
var classBreakStyle =newClassBreakStyle("ResultsData");
// Set up the first stylevar firstStyles =newCollection<Style>();firstStyles.Add(PointStyles.CreateSimpleCircleStyle(newGeoColor(100, GeoColor.SimpleColors.Black),10));
if(ShowNames) firstStyles.Add( TextStyles.CreateSimpleTextStyle("Name","Arial", 9, DrawingFontStyles.Regular, GeoColor.StandardColors.Black, GeoColor.StandardColors.White, 2, 0, 0));
// Must start at double.MinValueclassBreakStyle.ClassBreaks.Add(newClassBreak(double.MinValue, firstStyles));
for(inti = 0; i < colors.Count - 1; i++){var styles =newCollection<Style>();styles.Add(PointStyles.CreateSimpleCircleStyle(ConvertToGeoColor(colors<i>.Color), 10));
if(ShowNames) styles.Add(TextStyles.CreateSimpleTextStyle("Name","Arial", 9, DrawingFontStyles.Regular, GeoColor.StandardColors.Black, GeoColor.StandardColors.White, 2, 0, 0));
classBreakStyle.ClassBreaks.Add(newClassBreak(colors<i>.Low, styles));}_pointsLayer.ZoomLevelSet.ZoomLevel01.CustomStyles.Clear();
_pointsLayer.ZoomLevelSet.ZoomLevel01.CustomStyles.Add(classBreakStyle);_pointsLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20;
and have attached a screen grab with the problems highlighted.
Is this a bug? or can I make some settings changes to make this go away
regards
Murray
