Popup Closed Event
In my web application, I display a map, and when the user clicks on a feature, I display a Cloud Popup with the HasCloseButton property set to true.
Is there anyway to catch the event of when the user closes the Cloud Popup in the map?
Treasa
 Hi Treasa,
Thanks for your post, I hope the following code could be helpful:
        var Map;
        function OnMapCreated(map) {
            Map = map;
            if (map.popups.length > 0) {
                OpenLayers.Event.stopObservingElement(map.popups[0].closeDiv, "click", OpenLayers.Function.bindAsEventListener(function () { this.hide(); }, map.popups[0]));
                OpenLayers.Event.observe(map.popups[0].closeDiv, "click", OpenLayers.Function.bindAsEventListener(closeCallBack, map.popups[0]));
        function closeCallBack() {
            Map.popups[0].hide();
            alert("good");
If you have any problem, please feel free to let us know.
Hope it helps.
</script>
Hi Johnny,
 Yes this works great on the client-side. Is there any way to catch this event on the server side? I was hoping to update other sections of the website using my code-behind page to do the work, not javascript.
 Treasa
Hi Treasa,
Please try the following code below,
Server side,
using System.Web.UI;
namespace CSSamples.Samples.Features
    public partial class AreaOfAFeature : System.Web.UI.Page,ICallbackEventHandler
        string returnvalue = "";
        public string GetCallbackResult()
        { return returnvalue; }
        public void RaiseCallbackEvent(string eventArgument)
        {returnvalue = "ServerSideAlter";}
Client side,
(script type="text/javascript")
        var Map;
            Map = map;
            var param="closeBoxClosed";
            <%= ClientScript.GetCallbackEventReference(this, "param", "receiveServerData", null)%>;
        function receiveServerData(columnValue){
            alert(columnValue);
    (/script)
The (script) means the <script>
Edgar
Hi Edgar,
 Thank you - this also works great.
 However, is there any way to capture this event as an asp:AsyncPostBackTrigger for an update panel? Does this make sense?
 Thank you for any insight you have.
 Treasa
Hi Treasa,
 I am afraid not, after setting “popup.HasCloseButton = true;”, the server side just write a “hasclosebox=true” into json, then the client will parse “hasclosebox=true” then create a div as a closebox, but as far as I know the updatepanel does not support .
 Hope it helps
 Edgar
Hi Edgar,
 Just FYI, and for anyone else who may need it…I came up with an alternate solution. Thank you very much for getting me started in the right direction.
 I did not use Callbacks, I used a Partial Postback.
 Javascript Code:
var Map;
                Map = map;
                    OpenLayers.Event.stopObservingElement(map.popups[0].closeDiv, “click”, OpenLayers.Function.bindAsEventListener(function () { this.hide(); }, map.popups[0]));
                    OpenLayers.Event.observe(map.popups[0].closeDiv, “click”, OpenLayers.Function.bindAsEventListener(closeCallBack, map.popups[0]));
                __doPostBack(’<%=UpdatePanel1.ClientID %>’, “PopupClosed”);
 Then in the ASPX code, I added the OnLoad event to UpdatePanel1:
<asp:UpdatePanel ID=“UpdatePanel1” runat=“server” OnLoad=“UpdatePanel1_Load”>
 Then in the code-behind, I implemented the UpdatePane1_Load function:
protected void UpdatePanel1_Load(object sender, EventArgs e)
            if (Request["__EVENTARGUMENT"] == “PopupClosed”)
                GridView1.SelectedIndex = -1;
Hi Treasa,
 I am glad to hear that you found a solution, and thanks for your sharing, if you have any question, please feel free to let me know.
