PostgreSql FeatureLayer
      I have setup a map with a PostgreSqlFeatureLayer as the code below, but on clicking a station point no one feature is found. am I doing something wrong ?
Thanks in advance
Paolo Saudin
            if (!Page.IsPostBack)
                 * map properties
                 * map tools
                Map1.MapTools.OverlaySwitcher.Enabled = true;
                Map1.MapTools.OverlaySwitcher.BackgroundColor = GeoColor.StandardColors.Lavender;
                Map1.MapTools.OverlaySwitcher.BaseOverlayTitle = "Mappa";
                Map1.MapTools.OverlaySwitcher.DynamicOverlayTitle = "Layers";
                Map1.MapTools.PanZoomBar.Enabled = true;
                Map1.MapTools.PanZoomBar.IsGlobeButtonEnabled = false;
                Map1.MapTools.MouseCoordinate.Enabled = true;
                Map1.MapTools.MouseMapTool.Enabled = true;
                Map1.MapTools.ScaleLine.Enabled = true;
                 * main layer
                GoogleOverlay googleOverlay = new GoogleOverlay("GoogleOverlay");
                googleOverlay.JavaScriptLibraryUri = new Uri(ConfigurationManager.AppSettings["GoogleUri"]);
                googleOverlay.GoogleMapType = GoogleMapType.Normal;
                 * stations layer
                PostgreSqlFeatureLayer stationsLayer = null;
                string connectString = "Server=localhost;User Id=postgres;Password=postgres;DataBase=rete_llpp;";
                stationsLayer = new PostgreSqlFeatureLayer(connectString, "metadati_postgis", "st_id", 23032, "metadata", "geometria");
                stationsLayer.Name = "Stations Layer";
                stationsLayer.ZoomLevelSet.ZoomLevel01.DefaultPointStyle = new PointStyle(PointSymbolType.Circle, new GeoSolidBrush(GeoColor.SimpleColors.DarkBlue), 9);
                stationsLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level12;
                 * manage the projection
                proj4.InternalProjectionParametersString = Proj4Projection.GetEpsgParametersString(23032);
                 * create overlays
                // stations
                LayerOverlay stationsOverlay = null;
                if (stationsLayer != null)
                    stationsOverlay = new LayerOverlay("Stations Overlay", false, TileType.SingleTile); // , false, TileType.SingleTile
                    stationsOverlay.Layers.Add("Stations Layer", stationsLayer);
                    stationsOverlay.TransitionEffect = TransitionEffect.None;
                    stationsLayer.FeatureSource.Projection = proj4;
                 * finally add all the layers
                if (googleOverlay != null) { Map1.CustomOverlays.Add(googleOverlay); }
                if (stationsOverlay != null) { Map1.CustomOverlays.Add(stationsOverlay); }
                 * sets the extents
                stationsLayer.Open();
                Map1.CurrentExtent = stationsLayer.GetBoundingBox();
                stationsLayer.Close();
        protected void Map1_Click(object sender, MapClickedEventArgs e)
            LayerOverlay staticOverlay = (LayerOverlay)Map1.CustomOverlays["Stations Overlay"];
            PostgreSqlFeatureLayer shapeFileLayer = (PostgreSqlFeatureLayer)(staticOverlay.Layers[0]);
            PointShape pointShape = (PointShape)e.Position;
            shapeFileLayer.ConnectionString = connectString;
            shapeFileLayer.Open();
            Collection<Feature> selectedFeatures = shapeFileLayer.QueryTools.GetFeaturesContaining(pointShape, ReturningColumnsType.AllColumns);
            shapeFileLayer.Close();
            CloudPopup popup;
            if (Map1.Popups.Count == 0)
                popup = new CloudPopup("Popup", e.Position, string.Empty, 260, 60);
                popup.IsVisible = true;
                Map1.Popups.Add(popup);
            else
                popup = (CloudPopup)Map1.Popups["Popup"];
                popup.Position = e.Position;
            popup.ContentHtml = GetPopupContent(selectedFeatures);
        private static string GetPopupContent(Collection<Feature> features)
            string content;
            if (features.Count > 0)
                StringBuilder message = new StringBuilder();
                message.AppendFormat("
  • Station Name : {0}
  • ", features[0].ColumnValues["stazione"].Trim());
                    string messageInPopup = String.Format("{0}", message.ToString());
                    content = messageInPopup;
                else
                    content = @"Clicca su di un punto per ottenere le informazioni.";
                return content;
    Paolo,
    I think the problem comes from the line of code “Collection selectedFeatures = shapeFileLayer.QueryTools.GetFeaturesContaining(pointShape, ReturningColumnsType.AllColumns);”. When we click on the map, the application just can get a point where we click, it should a coordinate (X, Y), but the stations also are presented by (X, Y) coordinates. I think it’s hard to say one point contains another point without any buffer, right? So please use “shapeFileLayer.QueryTools.GetFeaturesNearestTo” instead.
    Hi Johnny,
       it works like a charm !! I’am really new to gis stuff …
     Thank you very much !!
     paolo
    Hi Paolo,
     That’s great. Any questions please let us know.
