PostgreSQL/PostGIS limitation?
I've been wrking with the beta 2 on PostGIS 1.3.5 for PostgreSQL 8.3 and have noticed that i cannot load my layers from a View in the database, only raw Tables work. I get an error message that says "Object reference not set to an instance of the object".
I am really hoping that this is only because the functionality has not yet been implemented (beta). A major reason for geodatabases is the server side capabilities (indexing, data sub-sets) which lower the client's overheads to a great deal. Without the support for Views (maybe hopefully even being able to pass SQL parameters to the server) ... how disappointing it would be!
Can I be informed what the expected scope of functionality is (concerning PostgreSQL) for the final release?
-F
Fifi,
First, thanks for joining this forum, hope you enjoy learning and sharing here.
You are right that the current Beta only support getting data from a Table but a View. Here we recompiled a Postgre Extension for you which supports reading from a View, please replace the existing one and have another try. Let us know how you think about it and if it's good, we will involve it in the next version.
380-PostgreExtension.zip (11.4 KB)
Ben,
 Thanks for the response. The new PostgreExtension worked. I am now able to render layers from Views in PostgreSQL. However I still have a problem. Running the ExecuteQuery function on a PostgreSqlFeatureLayer object yields an exception that says it is not possible to do that and that I should run a check on the CanExecuteQuery property. Is there another normal way to access the data behind the layer or this is another feature that will be in the final?
 (FYI, I connected to the database as a fully privileged user)
 Thanks a lot.
 Fifi
Fifi,
 We don’t support ExecuteQuery for PostGRE now and we will add this feature in the final release. Thanks for reminding!
