Pre-Generate Map Tiles
I need to pre-generate map tiles using custom scales.
I tried using  Cache Generator application and modified it to use custom scales but the filename of the tile (cell’s row and column) does not match with the auto generated tile (from client app).
Am I missing something?
P.S.
I opened new ticket #7318 with the attachments, but didn’t get any response for 5 days.
Thank you,
Inna
Hi Inna,
 Thanks for your post, would you please tell us did you also used custome scales on clientapp? and would you please provide some cahced images from both CacheGenerator and Client app to observe the difference?
 waiting for your further informaiton.
 Best Regards
 Summer
Hi Summer,
In both applications I’m using the same scales (same code).
Because of the size limitation, I’ve attached cached images to the ticket.
Thank you for your help.
Inna
Hi Inna,
 Thanks for your data, but I am sorry to say that the download for your data didn’t successed on our end, we tried both IE and Chrome, would you please send it to forumsupport@thinkgeo.com ? And would you please also provide us the custom-scales  setting code on client app?
 Waiting for your further information.
 Best Regards
 Summer
Hi Summer,
I’ve sent you 3 separate emails. Did you receive them?
Inna
Hi Inna,
Sorry for the convenience.
We are trying to recreate your issue with custom zoom level, but failed. Here is the video recorded what we did. Please have a look at screencast.com/t/zc7pYMmD8pOO . And also we attached our test sample, one is the CacheGenerater Tool which have been modified to fit the requirement, and the other one is the wpf client app.
Please double check the difference between your applications and the attahced. I guess there are some differences between them.
Btw, we test our sample with the latest version (7.0.0.122), would you let us know which version you are using? There is a big change between 6.0 and 7.0.
Post11570.zip (26.8 KB)
