some problems with printing.
I have implemented the PrintingSample but when changing the scale of a printing area point symbols will bescaled:
Changing from current scale 1:500 to 1:1000 symbols will increase size. Scaling down symbols will decrease.
I’m using the GeoImage objects to display points.
Do I have to handle them with a special way when printing?
Regards
Hardy
Printing, Pointsymbols will be scaled
Hi Hardy,
It looks GeoImage should be keep in same size, and I haven’t found its size change.
Are you using our Printing sample or created your project? Please tell me more detail about how to reproduce it if you are using our sample, and please provide me more detail code if you found that in your project.
That should be helpful for reproduce this problem, and I want to know the detail verison of your dlls.
Hi Don,
sorry getting back late…we have a bit of bank holidays…
I’m using the Printing sample (attached my code).
We are using different projection (EPSG: 25832, 31466, 31467) and we use Centimeter or Meter.
Maybe that’s causing the problems?
I hvae copied my code from the editor and reduced, so there should be only the relevant sub’s.
Regards
Here is my code:
Imports PdfSharp
Imports PdfSharp.Pdf
Imports System.Collections.ObjectModel
Imports ThinkGeo.MapSuite.Core
Imports ThinkGeo.MapSuite.DesktopEdition
Imports System.Drawing.Printing
Public Class PlotForm
Public ParentMap As WinformsMap
Public ScaleFactor As Double = 2.54 / 100
Public PointScale As Double = 595 / 21
Public Plotframe As DataRow
Public Frameparts As DataTable
Public MyParent As Host
Public mapPrinterLayer As New MapPrinterLayer
Private Sub Sample_Load(sender As Object, e As EventArgs) Handles Me.Load
RibbonBar.StartButtonImage = Host.RibbonBar.StartButtonImage
SetupMapWithBlankPage()
'load parts if defined…
If Frameparts.Select(“frame=” & Plotframe.Item(“id”)).GetLength(0) > 0 Then
For Each part As DataRow In Frameparts.Select(“frame=” & Plotframe.Item(“id”))
Select Case part.Item(“typ”)
Case “Label”
AddCenteredLabel(part)
Case “Drawing”
AddMapLayer(part.Item(“width”), part.Item(“height”), part.Item(“partvalue”), part.Item(“center_x”), part.Item(“center_y”))
Case “Image”
AddImage(part)
Case “Grid”
Case “Scalebar”
Case “Legend”
End Select
Next
Else
AddCenteredTitleLabel()
AddMapLayer()
AddLogoImage()
End If
SetPageSize()
winformsMap1.Refresh()
End Sub
Private Sub SetupMapWithBlankPage()
’ Setup the map unit, you want to always use feet or meters for printer layout maps
winformsMap1.MapUnit = GeographyUnit.Meter
’ Here we create the default zoom levels for the sample. We have pre-created a PrinterZoomLevelSet
’ That pre-defines commonly used zoom levels based on percentages of zoom
winformsMap1.ZoomLevelSet = New PrinterZoomLevelSet(winformsMap1.MapUnit, PrinterHelper.GetPointsPerGeographyUnit(winformsMap1.MapUnit))
’ Here we set the background color to gray so there is contrast with the while page
winformsMap1.BackgroundOverlay.BackgroundBrush = New GeoSolidBrush(GeoColor.StandardColors.LightGray)
’ Create the PrinterInteractiveOverlay to contain all of the PrinterLayers.
’ The interactive overlay allows the layers to be interacted with
Dim printerOverlay As New PrinterInteractiveOverLay()
winformsMap1.InteractiveOverlays.Add(“PrintPreviewOverlay”, printerOverlay)
winformsMap1.InteractiveOverlays.MoveToBottom(“PrintPreviewOverlay”)
’ Create the PagePrinterLayer which shows the page boundary and is the area the user will
’ arrange all of the other layer on top of.
Dim pagePrinterLayer As New PagePrinterLayer(PrinterPageSize.AnsiA, PrinterOrientation.Portrait)
pagePrinterLayer.Open()
printerOverlay.PrinterLayers.Add(“PageLayer”, pagePrinterLayer)
’ Get the pages extent, slightly scale it up, and then set that as the default current extent
winformsMap1.CurrentExtent = RectangleShape.ScaleUp(pagePrinterLayer.GetPosition(), 0).GetBoundingBox()
’ Set the minimum scale of the map to the last zoom level
winformsMap1.MinimumScale = winformsMap1.ZoomLevelSet.ZoomLevel20.Scale
End Sub
Private Sub AddCenteredTitleLabel()
Dim labelPrinterLayer As New LabelPrinterLayer()
'Setup the text and the font…
labelPrinterLayer.Text = “gisME®”
labelPrinterLayer.Font = New GeoFont(“Arial”, 20, DrawingFontStyles.Bold)
labelPrinterLayer.TextBrush = New GeoSolidBrush(GeoColor.StandardColors.Black)
labelPrinterLayer.PrinterWrapMode = PrinterWrapMode.AutoSizeText
’ Set the labels position so that is it centered on the page one inch from the top
Dim pageBoundingbox As RectangleShape = GetPageBoundingBox(PrintingUnit.Centimeter)
Dim labelCenter As New PointShape()
labelCenter.X = pageBoundingbox.UpperRightPoint.X - pageBoundingbox.Width / 2
labelCenter.Y = Plotframe.Item(“height”) / 2 - 1.5 'pageBoundingbox.UpperLeftPoint.Y '- pageBoundingbox.Height / 2 + 0.5
labelPrinterLayer.SetPosition(5, 1, labelCenter, PrintingUnit.Centimeter)
’ Find the PrinterInteractiveOverlay so we can add the new LabelPrinterLayer
Dim printerInteractiveOverLay As PrinterInteractiveOverLay = DirectCast(winformsMap1.InteractiveOverlays(“PrintPreviewOverlay”), PrinterInteractiveOverLay)
printerInteractiveOverLay.PrinterLayers.Add(“LabelLayer”, labelPrinterLayer)
End Sub
Public Function GetGeoColor(argb As String) As GeoColor
Try
Dim color() As String = Split(argb, “,”)
Return GeoColor.FromArgb(CInt(color(0)), CInt(color(1)), CInt(color(2)), CInt(color(3)))
Catch ex As Exception
Return Nothing
End Try
End Function
Private Sub AddCenteredLabel(part As DataRow)
Try
With part
labelPrinterLayer.Text = .Item(“partvalue”).ToString
labelPrinterLayer.Font = New GeoFont(.Item(“font”).ToString, .Item(“size”), .Item(“style”))
labelPrinterLayer.TextBrush = New GeoSolidBrush(GetGeoColor(.Item(“txtcolor”).ToString))
'Dim pageBoundingbox As RectangleShape = GetPageBoundingBox(PrintingUnit.Centimeter)
labelCenter.X = .Item(“center_x”)
labelCenter.Y = .Item(“center_y”)
labelPrinterLayer.SetPosition(.Item(“width”), .Item(“height”), labelCenter, PrintingUnit.Centimeter)
printerInteractiveOverLay.PrinterLayers.Add(“LabelLayer” & .Item(“id”).ToString, labelPrinterLayer)
End With
Catch e As Exception
End Try
End Sub
Private Sub AddMapLayer(width As Double, height As Double, scale As Double, Optional x As Double = 0, Optional y As Double = 0)
’ Create the MapPrinterLayer and set the position
Dim mapPrinterLayer As New MapPrinterLayer()
mapPrinterLayer.MapUnit = ParentMap.MapUnit
mapPrinterLayer.BackgroundMask = New AreaStyle(New GeoPen(GeoColor.StandardColors.Black, 1))
mapPrinterLayer.DrawingMode = MapPrinterDrawingMode.Raster
mapPrinterLayer.Open()
If x <= 0 Then
x = pageBoundingbox.GetCenterPoint().X
End If
If y <= 0 Then
y = pageBoundingbox.GetCenterPoint().Y '+ 1
End If
mapPrinterLayer.SetPosition(width, height, x, y, PrintingUnit.Centimeter)
'Setup the intial extent and ensure they snap to the default ZoomLevel
Dim zoomLevelSet As ZoomLevelSet = New ZoomLevelSet()
Try
mapPrinterLayer.MapExtent = ExtentHelper.ZoomToScale(scale, ParentMap.CurrentExtent, mapPrinterLayer.MapUnit, mapPrinterLayer.GetBoundingBox().Width, mapPrinterLayer.GetBoundingBox().Height)
End Try
Dim MyOverlay As LayerOverlay = Nothing
For Each MyOverlay In ParentMap.Overlays
For Each MyLayer In MyOverlay.Layers
mapPrinterLayer.Layers.Add(MyLayer)
Next
Next
’ Add the MapPrinterLayer to the PrinterInteractiveOverlay
printerInteractiveOverLay.PrinterLayers.Add(“MapLayer” & Now.Ticks, mapPrinterLayer)
End Sub
Private Sub AddMapLayer(Optional X As Double = 0, Optional y As Double = 0)
If X <= 0 Then
X = pageBoundingbox.GetCenterPoint().X
End If
If y <= 0 Then
End If
mapPrinterLayer.SetPosition(Plotframe.Item(“width”) - 2, Plotframe.Item(“height”) - 2, X, y, PrintingUnit.Centimeter)
Try
mapPrinterLayer.MapExtent = ExtentHelper.ZoomToScale(ParentMap.CurrentScale, ParentMap.CurrentExtent, mapPrinterLayer.MapUnit, mapPrinterLayer.GetBoundingBox().Width, mapPrinterLayer.GetBoundingBox().Height)
End Try
Next
Next
printerInteractiveOverLay.PrinterLayers.Add(“MapLayer”, mapPrinterLayer)
End Sub
#Region “Export Buttons”
Private Sub btnPrintPreview_Click(sender As Object, e As EventArgs) Handles btnPrintPreview.Click
Dim pagePrinterLayer As PagePrinterLayer = TryCast(printerInteractiveOverLay.PrinterLayers(“PageLayer”), PagePrinterLayer)
Dim printDialog As New PrintDialog()
Dim printDocument As New PrintDocument()
printDocument.DefaultPageSettings.Landscape = True
If pagePrinterLayer.Orientation = PrinterOrientation.Portrait Then
printDocument.DefaultPageSettings.Landscape = False
End If
printDocument.DefaultPageSettings.PaperSize = GetPrintPreviewPaperSize(pagePrinterLayer)
Dim printerGeoCanvas As New PrinterGeoCanvas()
printerGeoCanvas.DrawingArea = printDocument.DefaultPageSettings.Bounds
printerGeoCanvas.BeginDrawing(printDocument, pagePrinterLayer.GetBoundingBox(), winformsMap1.MapUnit)
’ Loop through all of the PrintingLayer in the PrinterInteractiveOverlay and print all of the
’ except for the PagePrinterLayer
Dim labelsInAllLayers As New Collection(Of SimpleCandidate)()
For Each printerLayer As PrinterLayer In printerInteractiveOverLay.PrinterLayers
printerLayer.IsDrawing = True
If Not (TypeOf printerLayer Is PagePrinterLayer) Then
printerLayer.Draw(printerGeoCanvas, labelsInAllLayers)
End If
printerLayer.IsDrawing = False
Next
printerGeoCanvas.Flush()
Dim printPreviewDialog As New PrintPreviewDialog()
printPreviewDialog.Document = printDocument
Dim dialogResult As DialogResult = printPreviewDialog.ShowDialog()
End Sub
Private Sub btnExportBitmap_Click(sender As Object, e As EventArgs) Handles btnExportBitmap.Click
’ Create a bitmap that is the size of the pages bounding box. The page by default is in points unit
’ system which is very similar to pixels so that ampping is nice.
Dim bitmap As Bitmap = Nothing
Try
bitmap = New Bitmap(CInt(pagePrinterLayer.GetBoundingBox().Width), CInt(pagePrinterLayer.GetBoundingBox().Height))
’ Create a GdiPlusGeoCanvas and start the drawing
Dim gdiPlusGeoCanvas As New GdiPlusGeoCanvas()
gdiPlusGeoCanvas.BeginDrawing(bitmap, pagePrinterLayer.GetBoundingBox(), winformsMap1.MapUnit)
printerLayer.Draw(gdiPlusGeoCanvas, labelsInAllLayers)
End If
Next
’ End the drawing
gdiPlusGeoCanvas.EndDrawing()
'Save the resulting bitmap to a file and open the file to show the user
Dim filename As String = “PrintingResults.bmp”
bitmap.Save(filename)
Process.Start(filename)
MessageBox.Show(ex.Message + " " + ex.StackTrace, “Exception”)
Finally
If bitmap IsNot Nothing Then
bitmap.Dispose()
End If
End Try
End Sub
Private Sub btnExportToPdf_Click(sender As Object, e As EventArgs) Handles btnExportToPdf.Click
’ Get the PrinterInteractiveOverlay and PagePrinterLayer as we are going to need them below
Dim pdfDocument As PdfDocument = Nothing
Dim pdfPage As PdfPage = Nothing
Try
’ Create the PDF documents, pages, and configure them
pdfDocument = New PdfDocument()
pdfPage = pdfDocument.AddPage()
If Plotframe.Item(“portrait”) Then
pdfPage.Orientation = PageOrientation.Portrait
Else
pdfPage.Orientation = PageOrientation.Landscape
End If
Dim currentSize As Integer = GetPdfPageSize(pagePrinterLayer.PageSize)
If currentSize = PageSize.Undefined Then
pdfPage.Width = pagePrinterLayer.CustomWidth * ScaleFactor * PointScale
pdfPage.Height = pagePrinterLayer.CustomHeight * ScaleFactor * PointScale
Else
pdfPage.Size = currentSize
End If
Dim pdfPrintDialog As New PDF_Printer
pdfPrintDialog.ShowDialog()
If pdfPrintDialog.SelectedFileName = “” Then
Exit Sub
End If
With pdfDocument.Info
.Author = pdfPrintDialog.selAutor
.Keywords = pdfPrintDialog.selBeschreibung
.Subject = pdfPrintDialog.selThema
.Title = pdfPrintDialog.selTitle
End With
’ Create the PdfGeoCanvas and pass tha PdfPage into the BeginDrawing
Dim pdfGeoCanvas As New PdfGeoCanvas()
pdfGeoCanvas.BeginDrawing(pdfPage, pagePrinterLayer.GetBoundingBox(), winformsMap1.MapUnit)
’ Loop through all of the PrinterLayers and draw them to the canvas except for the
’ PagePrinterLayer which is just used for the visual layout
printerLayer.Draw(pdfGeoCanvas, labelsInAllLayers)
End If
Next
’ Finish up the drawing
pdfGeoCanvas.EndDrawing()
’ Dave the PDF document and launch it in the default viewer to show the user
Dim filename As String = pdfPrintDialog.SelectedFileName
Try
pdfDocument.Save(filename)
System.Diagnostics.Process.Start(filename)
MsgBox(“Fehler bei der Erstellung der PDF-Datei.” & ex.Message, MsgBoxStyle.Exclamation Or MsgBoxStyle.OkOnly)
End Try
Finally
If pdfDocument IsNot Nothing Then
pdfDocument.Dispose()
End If
End Try
End Sub
Private Sub btnPrint_Click(sender As Object, e As EventArgs) Handles btnPrint.Click
End If
printerGeoCanvas.DrawingArea = New Rectangle(0, 0, Convert.ToInt32(printDocument.DefaultPageSettings.PrintableArea.Width), Convert.ToInt32(printDocument.DefaultPageSettings.PrintableArea.Height))
End If
Next
printerGeoCanvas.EndDrawing()
End Sub
#End Region
#Region “Map Events”
Private Sub winformsMap1_CurrentScaleChanged(sender As Object, e As CurrentScaleChangedWinformsMapEventArgs)
’ Here we sync up the zoom combox to the map’s zoom level.
Dim printerZoomLevelSet As PrinterZoomLevelSet = DirectCast(winformsMap1.ZoomLevelSet, PrinterZoomLevelSet)
Dim currentZoomLevel As ThinkGeo.MapSuite.Core.ZoomLevel = printerZoomLevelSet.GetZoomLevel(winformsMap1.CurrentExtent, winformsMap1.Width, winformsMap1.MapUnit)
'cboZoom.SelectedItem = printerZoomLevelSet.GetZoomPercentage(currentZoomLevel) & “%”
currentScale.Text = CInt(winformsMap1.CurrentScale)
End Sub
Private Sub winformsMap1_MapClick(sender As Object, e As MapClickWinformsMapEventArgs)
’ Here we loop through all of the PrinterLayers to find the one the user right mouse clicked on.
’ Then we show the right click menu to give the user some options
If e.MouseButton = MapMouseButton.Right Then
Dim printerOverlay As PrinterInteractiveOverLay = DirectCast(winformsMap1.InteractiveOverlays(“PrintPreviewOverlay”), PrinterInteractiveOverLay)
For i As Integer = printerOverlay.PrinterLayers.Count - 1 To 0 Step -1
If printerOverlay.PrinterLayers(i).[GetType]() <> GetType(PagePrinterLayer) Then
Dim boundingBox As RectangleShape = printerOverlay.PrinterLayers(i).GetPosition()
If boundingBox.Contains(e.WorldLocation) Then
cmRightClick.Tag = printerOverlay.PrinterLayers(i)
cmRightClick.Show(winformsMap1, New Point(CInt(e.ScreenX), CInt(e.ScreenY)))
Exit For
End If
End If
Next
End If
End Sub
#End Region
#Region “Pan & Zoom Buttons”
Private Sub btnZoomIn_Click(sender As Object, e As EventArgs) Handles btnZoomIn.Click
’ Grab the MapPrinterLayer and adjust the extent
Dim mapPrinterLayer As MapPrinterLayer = DirectCast(printerOverlay.PrinterLayers(“MapLayer”), MapPrinterLayer)
’ Here we snap the current scale to the default zoomLevelSet when we zoom in
Dim zoomLevelSet__1 As New ZoomLevelSet()
Dim newScale As Double = ZoomLevelSet.GetLowerZoomLevelScale(ExtentHelper.GetScale(mapPrinterLayer.MapExtent, CSng(mapPrinterLayer.GetBoundingBox().Width), mapPrinterLayer.MapUnit), zoomLevelSet__1)
mapPrinterLayer.MapExtent = ExtentHelper.ZoomToScale(newScale, mapPrinterLayer.MapExtent, mapPrinterLayer.MapUnit, CSng(mapPrinterLayer.GetBoundingBox().Width), CSng(mapPrinterLayer.GetBoundingBox().Height))
End Sub
Private Sub btnZoomOut_Click(sender As Object, e As EventArgs) Handles btnZoomOut.Click
’ Here we snap the current scale to the default zoomLevelSet when we zoom out
Dim newScale As Double = ZoomLevelSet.GetHigherZoomLevelScale(ExtentHelper.GetScale(mapPrinterLayer.MapExtent, CSng(mapPrinterLayer.GetBoundingBox().Width), mapPrinterLayer.MapUnit), zoomLevelSet__1)
End Sub
Private Sub btnPan_Click(sender As Object, e As EventArgs) Handles btnPanUp.Click, btnPanRight.Click, btnPanLeft.Click, btnPanDown.Click
Dim b As Button = sender
Select Case b.Name
Case “btnPanUp”
mapPrinterLayer.MapExtent = ExtentHelper.Pan(mapPrinterLayer.MapExtent, PanDirection.Up, 30)
Case “btnPanDown”
mapPrinterLayer.MapExtent = ExtentHelper.Pan(mapPrinterLayer.MapExtent, PanDirection.Down, 30)
Case “btnPanLeft”
mapPrinterLayer.MapExtent = ExtentHelper.Pan(mapPrinterLayer.MapExtent, PanDirection.Left, 30)
Case “btnPanRight”
mapPrinterLayer.MapExtent = ExtentHelper.Pan(mapPrinterLayer.MapExtent, PanDirection.Right, 30)
End Select
End Sub
#End Region
#Region “Combo Boxes”
Sub SetPageSize()
Dim pagePrinterLayer As PagePrinterLayer = DirectCast(printerInteractiveOverLay.PrinterLayers(“PageLayer”), PagePrinterLayer)
With pagePrinterLayer
.CustomWidth = Plotframe.Item(“width”) / ScaleFactor
.CustomHeight = Plotframe.Item(“height”) / ScaleFactor
.PageSize = PrinterPageSize.Custom
If .CustomWidth > .CustomHeight Then
'Else
’ .Orientation = PrinterOrientation.Portrait
End If
End With
End Sub
#End Region
#Region “Toolbox”
Private Sub toolStrip1_ItemClicked(sender As Object, e As ToolStripItemClickedEventArgs)
Dim printerLayer As PrinterLayer = Nothing
Dim name As String = e.ClickedItem.Text.ToLower()
Select Case name
Case “label”
printerLayer = New LabelPrinterLayer()
printerLayer.SetPosition(2, 1, 0, 0, PrintingUnit.Centimeter)
Exit Select
Case “image”
printerLayer = New ImagePrinterLayer()
Exit Select
Case “scale line”
MessageBox.Show(“NotImplemented”)
Exit Select
Case “scale bar”
Exit Select
Case “data grid”
printerLayer = New DataGridPrinterLayer()
printerLayer.SetPosition(1, 1, 0, 0, PrintingUnit.Centimeter)
Exit Select
Case Else
Exit Select
End Select
'If printerLayer IsNot Nothing AndAlso ShowPrinterLayerProperties(printerLayer) = DialogResult.OK Then
’ printerInteractiveOverLay.PrinterLayers.Add(printerLayer)
’ winformsMap1.Refresh()
'End If
End Sub
#End Region
#Region “Right Click and Dialogs”
Private Sub cmRightClick_Click(sender As Object, e As EventArgs)
End Sub
#End Region
#Region “Helper Methods”
Private Function GetPageBoundingBox(unit As PrintingUnit) As RectangleShape
’ This helper method gets the pages bounding box in the unit requested
Return pagePrinterLayer.GetPosition(unit)
End Function
Private Function GetPdfPageSize(pageSize1 As PrinterPageSize) As PageSize
Dim pdfPageSize As PageSize = PageSize.A4
Select Case pageSize1
Case PrinterPageSize.AnsiA
pdfPageSize = PageSize.Letter
Exit Select
Case PrinterPageSize.AnsiB
pdfPageSize = PageSize.Ledger
Exit Select
Case PrinterPageSize.AnsiC
pdfPageSize = PageSize.A2
Exit Select
Case PrinterPageSize.AnsiD
pdfPageSize = PageSize.A1
Exit Select
Case PrinterPageSize.AnsiE
pdfPageSize = PageSize.A0
Exit Select
Case PrinterPageSize.[Custom]
pdfPageSize = PageSize.Undefined
Case Else
Throw New NotSupportedException()
End Select
Return pdfPageSize
End Function
Private Function GetPrintPreviewPaperSize(pagePrinterLayer As PagePrinterLayer) As PaperSize
Dim printPreviewPaperSize As New PaperSize(“AnsiA”, 850, 1100)
Select Case pagePrinterLayer.PageSize
printPreviewPaperSize = New PaperSize(“AnsiA”, 850, 1100)
Exit Select
printPreviewPaperSize = New PaperSize(“AnsiB”, 1100, 1700)
Exit Select
printPreviewPaperSize = New PaperSize(“AnsiC”, 1700, 2200)
Exit Select
printPreviewPaperSize = New PaperSize(“AnsiD”, 2200, 3400)
Exit Select
printPreviewPaperSize = New PaperSize(“AnsiE”, 3400, 4400)
Exit Select
printPreviewPaperSize = New PaperSize(“Custom Size”, CInt(pagePrinterLayer.CustomWidth), CInt(pagePrinterLayer.CustomHeight))
Exit Select
Case Else
Exit Select
End Select
Return printPreviewPaperSize
End Function
#End Region
Private Sub Button1_Click(sender As Object, e As EventArgs) Handles Button1.Click
Try
Dim newScale As Double = cbScale.Text
End Try
End Sub
Public Sub New()
’ Dieser Aufruf ist für den Designer erforderlich.
InitializeComponent()
’ Fügen Sie Initialisierungen nach dem InitializeComponent()-Aufruf hinzu.
MyParent = My.Forms.Host
MyParent.SetRibbon(PlotRibbon)
End Sub
End Class
Hi Hartwig,
What a long source code! Thanks for sharing. Unfortunately, I found there are some something interferes me, so that I cannot get the point nor make it work. Could you try to upload an executable sample project or modify our existing sample (wiki.thinkgeo.com/mediawiki/images/f/fb/ServicesEditionSample_PrintPreview_CS_WPF_111115.zip) to show your issue? Also, it is good to provide us an exported XPS file, that will be a great help.
Thanks and looking forward your feedback,
Howard
Hi Howard,
I will extract the code and setup a smaller example…
But it’s a lot of work…
Get back to you asap.
Regards
Hardy
Hi Hartwig,
Thanks for your help on that, any update please let us know.
