Hi Ben,
Unfortunately we are still having a variety of issues including:
Tiles look muddled up.  I think they are the correct tiles but definitely in the wrong order and I have not picked up a pattern for how they are disarranged.
As you zoom in the tiles have gaps between
Adding a projected tile cache causes an error that shows as the message ‘Arithmetic operation resulted in an overflow’ instead of actual tiles.
The code looks like this:
        private static void InitialiseBackgrounds(MapView mapControl)
        // If the setting exists in the setting file, then osMapsAPIKey will come out with its corresponding value and it returns true
        // Otherwise it returns false (meaning the osMapsAPIKey will contain an empty value) and we set it to the default key
        // To add a user key use a line like this in the setting file:
        // <OSMapsAPIKey>xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx</OSMapsAPIKey>
        Setting settings = new Setting(Setting.Usage.DEFAULT, Setting.Areas.GENERAL);
        if (!settings.GetSettingsValues().TryGetValue(Setting.GeneralKeys.OSMAPS_API_KEY, out _osMapsAPIKey))
            SetStandardOSKey();
        if (!settings.GetSettingsValues().TryGetValue(Setting.GeneralKeys.MAPBOX_API_KEY, out _mapboxAPIKey))
            SetStandardMapBoxKey();
        osMapLayer = new WmtsAsyncLayer(new Uri("https://api.os.uk/maps/raster/v1/wmts"))
            Name = OS_BACKGROUND,
            AxisOrder = WmtsAxisOrder.XY,
            DrawingExceptionMode = DrawingExceptionMode.DrawException,
            WebProxy = null,
            ActiveLayerName = "Road_27700",
            ActiveStyleName = "Road",
            TileMatrixSetName = "EPSG:27700",
            IsVisible = true,
            OutputFormat = "image/png",
        osMapLayer.TileCache = CreateCacheForLayer(osMapLayer.ActiveLayerName, MapBackgroundLayerStyle.OSAPI);
        osMapLayer.SendingHttpRequest += OsMapLayer_SendingHttpRequest;
        mapBoxLayer = new WmtsAsyncLayer(new Uri("https://api.mapbox.com/styles/v1/lukeor/ckfy0j3ye01d019pfob9re2zi/wmts"))
            Name = MAPBOX_BACKGROUND,
            WebProxy = null,
            ActiveLayerName = "ckfy0j3ye01d019pfob9re2zi",
            ActiveStyleName = "default",
            TileMatrixSetName = "GoogleMapsCompatible",
            ProjectionConverter = new GdalProjectionConverter(3857, 27700),
            IsVisible = true,
        mapBoxLayer.TileCache = CreateCacheForLayer(mapBoxLayer.ActiveLayerName, MapBackgroundLayerStyle.SATELLITE);
        mapBoxLayer.ProjectedTileCache = CreateCacheForLayer(mapBoxLayer.ActiveLayerName, MapBackgroundLayerStyle.SATELLITE_PROJECTED);
        // Include the key as a parameter
        mapBoxLayer.Parameters.Add("access_token", _mapboxAPIKey);
        wmtsBackgrounds.Name = WMTS_OVERLAY_NAME;
        wmtsBackgrounds.Layers.Add(MAPBOX_BACKGROUND, mapBoxLayer);
        wmtsBackgrounds.Layers.Add(OS_BACKGROUND, osMapLayer);
        mapControl.Overlays.Add(WMTS_OVERLAY_NAME, wmtsBackgrounds);
        mapControl.Overlays.MoveToBottom(wmtsBackgrounds);
