Problem displaying shapefile and GdiPlusRasterLayer at the same time
I have an application that first displays a shape file and then displays a tif file with an attached tiff world file into a GdiPlusRasterLayer.  Each of these layers display without error when the other is not loaded, but when loading both I get an InvalidOperationException "You can not operate when the file has closed".  My attempts to fix this problem by doing the following did not work:
foreach (Overlay overlay in this.Map.Overlays)
    foreach (Layer layer in ((LayerOverlay)overlay).Layers)
        layer.Open();
I discovered my problem was that I was trying to access column data that did not exist in the dbf file.  After adding it, everything is working fine.
I am glad you find the fix by yourself.
