Problem in Displaying Multiple images
Hi
I am trying to display multiple png from the database. That showing nothing with no error. I think I m missing some thing here.
For i = 0 To dt.Rows.Count - 1
Dim UnitPointStyle As New PointStyle(New GeoImage("..\..\Images\primary_symbols\" & dt.Rows(i).Item("Symbolname")))
Dim Coordinates As New Feature(New PointShape(dt.Rows(i).Item("Longitude"), dt.Rows(i).Item("Latitude")))
pointLayer.FeatureSource.Projection = proj
pointLayer.ZoomLevelSet.ZoomLevel01.DefaultPointStyle.PointType = PointType.Bitmap
ValueStyle.ValueItems.Add(New ValueItem("Units", UnitPointStyle))
pointLayer.ZoomLevelSet.ZoomLevel01.CustomStyles.Add(ValueStyle)
pointLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20
pointLayer.InternalFeatures.Add(Coordinates)
Next
Dim UnitOverlay As New LayerOverlay()
UnitOverlay.Layers.Add("UnitOverlay", pointLayer)
winformsMap1.Overlays.Add(UnitOverlay)
Zeeshan
ZEESHAN,
First I did not see you set the correct map unit for the map control, can you make sure that has been done? Also, are you setting the correct boundingbox for the map control?
Also I reviewed the logic in the for each loop and found that something is confusing, I get some changes for reference, hope it helps:
Dim UnitPointStyle AsNew PointStyle(New GeoImage("..\..\Images\primary_symbols\" & dt.Rows(i).Item("Symbolname")))
Dim Coordinates AsNew Feature(New PointShape(dt.Rows(i).Item("Longitude"), dt.Rows(i).Item("Latitude")))
Next
Any more questions or concerns please feel free to let me know.
Hi Yale !
The projection that I m using
proj.InternalProjectionParameters = ManagedProj4Projection.GetEpsgParameters(4326)  'WGS84
proj.ExternalProjectionParameters = ManagedProj4Projection.GetEpsgParameters(32638) 'UTM zone 38N
This works fine when I display single icon using following code
Dim inMemoryFeatureLayer As New InMemoryFeatureLayer()
inMemoryFeatureLayer.FeatureSource.Projection = proj
inMemoryFeatureLayer.ZoomLevelSet.ZoomLevel01.DefaultPointStyle.PointType = PointType.Bitmap
inMemoryFeatureLayer.ZoomLevelSet.ZoomLevel01.DefaultPointStyle.Image = New GeoImage("..\..\Images\sedan.png")
inMemoryFeatureLayer.ZoomLevelSet.ZoomLevel01.DefaultPointStyle.RotationAngle = 360
inMemoryFeatureLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20
inMemoryFeatureLayer.InternalFeatures.Add("Car", New Feature(New PointShape(47.3677, 29.3901)))
Dim car_overlay As New LayerOverlay()
car_overlay.Layers.Add("CarOverlay", inMemoryFeatureLayer)
winformsMap1.Overlays.Add(car_overlay)
After I made change to display multiple icons as u suggested still showing nothing
Dim dt As New DataTable
Dim i As Integer
Dim valueStyle As New ValueStyle
Dim pointLayer As New InMemoryFeatureLayer()
ValueStyle.ColumnName = "Type"
dt = getTable("select * from Units", "")
Dim UnitPointStyle As New PointStyle(New GeoImage("..\..\Images\primary_symbols\" & dt.Rows(i).Item("Symbol_name")))
valueStyle.ValueItems.Add(New ValueItem("Units", UnitPointStyle))
Next
pointLayer.ZoomLevelSet.ZoomLevel01.CustomStyles.Add(valueStyle)
Zeeshan
Waiting for reply
2 days ago no reply yet. i am desperately waiting for the solution.
Zeeshan
Zeeshan,
 Thanks for your post and sorry for the delay.
 I reviewed the code you provided, and I think the problem is probably because you did not assign a corresponding value for the feature before adding them into inMemoryFeatureLayer, which will cause no valid ValueItem can be found.  So please change this according to your logic, which will answering the questions why choosing ValueStyle.
Hi Yale!
I was missing to declare column in memory layer.New FeatureSourceColumn("Type", "string", 20))
Thats why i was unable to see any image. Plus as u suggested to assign valuestyle value to feature b4 adding in memoryfeaturelayer.Thanks its done
pointLayer.Columns.Add(
ZEESHAN,
 Thanks for letting me know your status.
