Problem in loading shapefile
I am facing problem in loading my shapefiel. when the application runs, shape file doesnot display. i have checked its map units and put correct map units but still no solution.
i have the same sample code
private void Form1_Load(object sender, EventArgs e)
            //winformsMap1.BackgroundOverlay.BackgroundBrush = new GeoSolidBrush(GeoColor.GeographicColors.ShallowOcean);
            //WorldMapKitWmsDesktopOverlay worldMapKitDesktopOverlay = new WorldMapKitWmsDesktopOverlay();
            //winformsMap1.Overlays.Add(worldMapKitDesktopOverlay);
            ShapeFileFeatureLayer worldLayer = new ShapeFileFeatureLayer(@"E:\Practices\First_attempt\First_attempt\bin\Debug\Shapefile\H_12_Roads.shp");
            worldLayer.ZoomLevelSet.ZoomLevel01.DefaultAreaStyle = AreaStyles.CreateSimpleAreaStyle(GeoColor.SimpleColors.Transparent, GeoColor.FromArgb(100, GeoColor.SimpleColors.Green));
            staticOverlay.Layers.Add("WorldLayer", worldLayer);
            //winformsMap1.CurrentExtent = new RectangleShape(-139.2, 92.4, 120.9, -93.2);
            winformsMap1.Refresh();
this is my code.
Hello Sarah,
 Thanks for your post, could you please provide your shape file to me and I can make some test, to make sure you using the right style, projection, mapunit.
 You can attach in this post, or you think your data is private, you can send to forumsupport@thinkgeo.com.
Thanks you i have send my shape file on the given email address
Thanks Gray i have solved this problem. but unfortunately i got an error in creating .rtg for routing. i searched the forum for the solution but i found same problem with same error but not could not find a solution.
 The error is :
 the decimal degree longitude value you provide was out of range . parameter name : from longitude
Sarah,
   Might I suggest you project your shapefile to spherical Mercator or a meters based projection.  The routing engine though it can work with decimal degrees is fastest and gives more reliable results when you use a feet or meters projection.  The reason is that in meters things are on a grid and the distance in one step of x or Y is know.  In decimal degrees one step being one decimal degree has different distances depending on where you are on the earth.  One decimal degree is different at the equator then near the poles. Converting the data may solve the error you are running into and also allow for a faster and more accurate result.
   On side benefit and something I suggest is to also use meters and then hook to the event that gets called when you create the rtg so you can adjust the weight.  By adjusting the weight you can factor in the speed difference between various classifications of roads.  My suggestion is to do the Distance / Speed as the weight.  You can look at your shapefile data and see if it has a road classification, if so estimate the speed.  In this was if you have a 5000 meter road with a speed of 75kph then the weight would be 66.66, this shortens the road as opposed to a speed of 45kph which would yield 111.11 meaning this road seems longer to the algorithm.  To do this with decimal degrees is tricky and I don’t suggest it.  If you do it this way then you results will be more accurate as it will factor in the faster possible travel speed of highways.
   We can provide you with a sample of this is you are interested.
Thanks david,
My shape file projection is in meters. I got error of this in creating .rtg in mapsuite explorer.
so how can i solve this problem? i follow the sample example given on mapsuite website.
Sarah,
   This might be a bug in the Map Suite Explorer in that it always thinks you data is in decimal degrees when generating the rtg file.  I suggest you use the direct API as part of the routing engine.  Below is a post of a person running into the same thing.
 He writes "There is an overload of RtgRoutingSource.GenerateRoutingData that takes GeographyUnit and DistanceUnit; we supply GeographyUnit.Meter and DistanceUnit.Meter and everything worked fine. "
 gis.thinkgeo.com/Support/DiscussionForums/tabid/143/aff/30/afv/topic/aft/10460/afc/32892/Default.aspx
i am building .rtg file with API is this correct method?
 ShapeFileFeatureSource featureSource = new ShapeFileFeatureSource(@"C:\Users\HP\Desktop\test\HelloWorld\bin\Debug\shapefile\H_12_Roads.shp");
             RtgRoutingSource routingSource = new RtgRoutingSource(@"C:\Users\HP\Desktop\test\HelloWorld\bin\Debug\shapefile\H_12_Roads.rtg");
             RtgRoutingSource.GenerateRoutingData(routingSource, featureSource,BuildRoutingDataMode.Rebuild, GeographyUnit.Meter, DistanceUnit.Meter);
             RoutingEngine routingEngine = new RoutingEngine(routingSource, featureSource);
Hello Sarah,
 For build the routing data(rtg) with API, you can refer HowDoISamples—>BuildingRoutingData, your code will be good but you don’t need
 RtgRoutingSource routingSource = new RtgRoutingSource(@“C:\Users\HP\Desktop\test\HelloWorld\bin\Debug\shapefile\H_12_Roads.rtg”);
 So have you met problem when you build the rtg file?
when i run this code
 ShapeFileFeatureSource featureSource = new ShapeFileFeatureSource(@“C:\Users\HP\Desktop\test\HelloWorld\bin\Debug\shapefile\Roads.shp”);
 RtgRoutingSource routingSource = new RtgRoutingSource(@“C:\Users\HP\Desktop\test\HelloWorld\bin\Debug\shapefile\Roads.rtg”);
 it gives this error :
 The decimal degree longitude value you provided was out of range.
 Parameter name: fromLongitude
 and when i add gernerateroutingdata in code
 it gives error
 Error 1 The best overloaded method match for ‘ThinkGeo.MapSuite.Routing.RtgRoutingSource.GenerateRoutingData(string, ThinkGeo.MapSuite.Core.FeatureSource, ThinkGeo.MapSuite.Routing.BuildRoutingDataMode, ThinkGeo.MapSuite.Core.GeographyUnit, ThinkGeo.MapSuite.Core.DistanceUnit)’ has some invalid arguments C:\Users\HP\Desktop\test\HelloWorld\Form1.cs 53 13 HelloWorld
 Error 2 Argument ‘1’: cannot convert from ‘ThinkGeo.MapSuite.Routing.RtgRoutingSource’ to ‘string’ C:\Users\HP\Desktop\test\HelloWorld\Form1.cs 53 50 HelloWorld
i still have problem in creating .rtg file with API.
Sarah,
   Is there any way you can send us your shapefile so we can try it here?  Send it to support@thinkgeo.com
i have send my shapefile and code on the given address.
Sarah,
  Thanks we will check it out and get right back to you. :-)
hello David,
I am waiting for your reply. i cannot move foward because of this .rtg file. my work has been delayed and stuck.
Kindly tell me the solution.
hi ThinkGeo,
 i have created  .rtg file by independent build routing data module as described in sample data . but when i used that .rtg file for routing it gives error
