Problem in Switching Overlay
I have issue with switching overlay. I have 3 overlays in map.
1. Local overlay
2. Bing map overlay
3. Open street overlay (OSM).
If initially I load local overlay as a BaseOverlay than if I switch from local to OSM or Bing than its work fine.
But If I load Bing map as a Baseoverlay than when I switch from Bing to Local overlay than its not working properly. its working for OSM layer  but not for Local overlay.
I have added three radio button not used map option for switching layer.
Here is my code for that.
$(document).ready(function () {
           //$(Map1.div).css(“height”, document.documentElement.clientHeight - 20);
           $(‘input#radioMapOption’).bind(‘click’, function () {
               if ($(this).is(’:checked’)) {
                   var mapname = $(this).val();
                   if (mapname == “Open Street”) {
                       Map1.getOpenLayersMap().setBaseLayer(Map1.getLayersByName(“OSMLayer”)[0]);
                       Map1.redrawLayer(“MarkerOverlay”);
                   else if (mapname == “Local”) {
                       Map1.getOpenLayersMap().setBaseLayer(Map1.getLayersByName(“ShapeOverlay”)[0]);
                   else {
                       Map1.getOpenLayersMap().setBaseLayer(Map1.getLayersByName(“BingMapOverlay”)[0]);
Please check the code and let me know If I made any mistake.
Eric.
 Is there any one who can help me in this issue. Need help urgently.
 Thank you.
 Eric.
Eric,
We created a sample for you, would you please modify it to fit your case?
Post12344.zip (587 KB)
