Problem trying to serialize MrSid Layer
In our project it is necessary to be able to save a map, all of its layers, the symbology, current extent, etc.  I have had very good luck with this until I tried to serialize a MrSidRasterLayer.  Then I get the following error:
Exception Source:      mscorlib
Exception Type:        System.Runtime.Serialization.SerializationException
Exception Message:     Type 'MapSuiteGeoRaster.GeoImage' in Assembly 'MapSuiteGeoRasterX86, Version=1.0.3295.16750, Culture=neutral, PublicKeyToken=null' is not marked as serializable.
Exception Target Site: InternalGetSerializableMembers
---- Stack Trace ----
   System.Runtime.Serialization.FormatterServices.InternalGetSerializableMembers(type As RuntimeType)
       GeoFrame.EXE: N 9452985
   System.Runtime.Serialization.FormatterServices.GetSerializableMembers(type As Type, context As StreamingContext)
       GeoFrame.EXE: N 00247
   System.Runtime.Serialization.Formatters.Binary.WriteObjectInfo.InitMemberInfo()
       GeoFrame.EXE: N 00160
   System.Runtime.Serialization.Formatters.Binary.WriteObjectInfo.InitSerialize(obj As Object, surrogateSelector As ISurrogateSelector, context As StreamingContext, serObjectInfoInit As SerObjectInfoInit, converter As IFormatterConverter, objectWriter As ObjectWriter, binder As SerializationBinder)
       GeoFrame.EXE: N 00218
   System.Runtime.Serialization.Formatters.Binary.ObjectWriter.Write(objectInfo As WriteObjectInfo, memberNameInfo As NameInfo, typeNameInfo As NameInfo)
       GeoFrame.EXE: N 00388
   System.Runtime.Serialization.Formatters.Binary.ObjectWriter.Serialize(graph As Object, inHeaders As Header[], serWriter As __BinaryWriter, fCheck As Boolean)
       GeoFrame.EXE: N 00444
   System.Runtime.Serialization.Formatters.Binary.BinaryFormatter.Serialize(serializationStream As Stream, graph As Object, headers As Header[], fCheck As Boolean)
       GeoFrame.EXE: N 00133
   System.Runtime.Serialization.Formatters.Binary.BinaryFormatter.Serialize(serializationStream As Stream, graph As Object)
       GeoFrame.EXE: N 00013
   PluginUtilities.Common.SaveWorkingSet(oPlugin As IGeoPlugin, sCurrentFileName As String)
       GeoFrame.EXE: N 00815
The RasterLayer base class and MrSidRasterLayer are both marked as serializable, according to the API documentation, however someting within the class is not.
Any chance this might work anytime soon?
Steve
Steven,
The reason is that the layer is open, you need to close it first and then do the serilaize, below is my test code:
            MrSidRasterLayer sidImageLayer = new MrSidRasterLayer(@"..\..\SampleData\Data\world.sid");
            sidImageLayer.UpperThreshold = double.MaxValue;
            sidImageLayer.LowerThreshold = 0;
            //sidImageLayer.Open();
            MemoryStream stream = new MemoryStream();
            BinaryFormatter formatter = new BinaryFormatter();
            formatter.Serialize(stream, sidImageLayer);
            stream.Seek(0, SeekOrigin.Begin);
            formatter.Deserialize(stream);
thanks
James,
 Thanks very much! It works fine now.
 Steve
Steven,
 I am glad it’s working with you, just let me know if you have more questions.
