Problem when container div is invisible at first
I have some popups which will load with style of “display:none”.
These DIVs should contain maps, But I’m experiencing some problem with maps when popup shows up.
for instance:
  • map.HeightInPixels is equals to zero (when returns to server side).
  • Mis-location of marker’s context menu .
Is there any work around? OR i should change the way all popups showing?
Hi Reza,
I think if you set the control disabled, invisible or hidden, that shouldn’t get initialized correct.
I am not sure why you need to hide the map when page loaded, but I think if that’s necessary, maybe you can try to load map with very small size or iframe.
