Problem with CurrentExtent
Hi, I'm testing you samples, and if don't remove de CurrentExtent sentence the map is not displayed. When I remove that line, the map is displayed but with the zoom at max level.
For other hand, if I click some button the map turns into blue backgroud and is not displayed. I have tested to remove all code from the button but the problem remains.
The code:
Imports System
Imports ThinkGeo.MapSuite.Core
Imports ThinkGeo.MapSuite.WebEdition
Partial Public Class _Default
    Inherits System.Web.UI.Page
    Protected Sub Page_Load(ByVal sender As Object, ByVal e As System.EventArgs) Handles Me.Load
        Map1.MapBackground.BackgroundBrush = New GeoSolidBrush(GeoColor.FromHtml("#B3C6D4"))
        Map1.CurrentExtent = New RectangleShape(-13939426.6371, 6701997.4056, -7812401.86, 2626987.386962)
        Map1.MapUnit = GeographyUnit.DecimalDegree
        Map1.MapTools.OverlaySwitcher.Enabled = True
        Map1.MapTools.MouseCoordinate.Enabled = True
        Dim yahoo As New YahooOverlay("Yahoo Map")
        yahoo.JavaScriptLibraryUri = New Uri("api.maps.yahoo.com/ajaxymap?v=3.8&appid=vrEddvTV34GIoAiUSmX5nCW4AJ3wNiefoYOH10knXAcMeU_yA44uDP_GRxOts2w-")
        yahoo.YahooMapType = YahooMapType.Regular
        If (Not Map1.CustomOverlays.Contains("Yahoo Map")) Then
            Map1.CustomOverlays.Add(yahoo)
        End If
        Dim markerOverlay As New InMemoryMarkerOverlay("Markers")
        markerOverlay.ZoomLevelSet.ZoomLevel01.DefaultMarkerStyle.Popup.ContentHtml = "Kansas City"
        markerOverlay.ZoomLevelSet.ZoomLevel01.DefaultMarkerStyle.Popup.HasCloseButton = True
        markerOverlay.ZoomLevelSet.ZoomLevel01.DefaultMarkerStyle.Popup.Width = 100
        markerOverlay.ZoomLevelSet.ZoomLevel01.DefaultMarkerStyle.Popup.Height = 30
        markerOverlay.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20
        If Not Map1.CustomOverlays.Contains("Markers") Then
            Map1.CustomOverlays.Add(markerOverlay)
        End If
    End Sub
    Protected Sub Button1_Click(ByVal sender As Object, ByVal e As EventArgs) Handles Button1.Click
        Dim markerOverlay As InMemoryMarkerOverlay = DirectCast(Map1.CustomOverlays("Markers"), InMemoryMarkerOverlay)
        If Not markerOverlay.Features.ContainsKey("Kansas") Then
            markerOverlay.Features.Add("Kansas", New Feature(-94.558, 39.078))
        End If
    End Sub
End Class
Thanks for the post!
We recreated your issue when we set the system’s region to French or Germany, so can you let me know what the region setting of your system is? You can check it from “Start”-> “Control Panel” ->”Region and Language”.  There is a known bug that the web edition doesn’t work properly with some certain regions; just want to make sure if this is your case. By the way, this bug will be solved in the next beta.
Also, there are 2 problems in your code.
1, Map1.MapUnit = GeographyUnit.DecimalDegree;
 you should use GeographyUnit.Meter, for yahoo is projected and its unit is meter.
2, if you want to add markers on Yahoo Map which is projected, you need to project the MarkerOverlay you added. Code will be like following:
proj4.InternalProjectionParametersString = proj4Projection.GetEpsgParametersString(4326);
// Yahoo Map has the same projection string as GoogleMap has
markerOverlay.FeatureSource.Projection = proj4;
And we have a sample here:
websamples.thinkgeo.com/webeditionsamples/
Markers->Add Projected Marker
Thank you for your reply Ben. I'm going to test your code. My system's region is Spain.
You’re welcome. We will have more test under different system environments and I think we will not have this “region” issue any more from next version.
