I have attached shape file.
1- if I open the file in MapSuit Explorer/show Features, as you can see in attached picture for [No Propert] column it just show 0 as value.
2- If I read the data using FeatureLayer.QueryTools.ExecuteQuery(QueryString) I will recieved same result(0 or very small numbers)
3-but If I use FeatureLayer.QueryTools.GetAllFeatures then it will return right value for the [No Propert] column.
I checked the dbf file in Excel and other GIS application and does not have any problem.
I think the problem is the engin you are using to run SQL-Queries.
Best Regards,
001_Shape_File.zip (1.33 KB)
