Problem with french reprojection (lambert2é and Lambert93)
I have a problem when I reproject a shapefile which has a Lambert2é projection to a Lambert93 projection.
There is a shift.
The shift is probably due to the fact that I have to use a grid transformation.
(georezo.net/forum/viewtopic.php?id=65396 ==> Utilisation transformation RGF_1993_To_NTF_NTv2)
I think I have the same problem as in this post thinkgeo.com/forums/MapSuite/tabid/143/aft/5627/Default.aspx
or this one thinkgeo.com/forums/MapSuite/tabid/143/aft/11769/Default.aspx
Is there a solution about this problem ?
Regards.
Steph.
Hi Steph,
Do you know what’s the EPSG code of the Lambert2é projection and Lambert93 projection? After we get them, we can use something like below:
            proj4.InternalProjectionParametersString = Proj4Projection.GetEpsgParametersString(Lambert2éEPSG);
            proj4.ExternalProjectionParametersString = Proj4Projection.GetEpsgParametersString(Lambert93EPSG);
Another option is we define a custom projection and then implement the two methods in projection,here is a sample to show it.
wiki.thinkgeo.com/wiki/Sourc…110127.zip
If any questions, please feel free to let us know.
