Problem with GeoTiff
We have a set of *.tif files that will not display properly in our application. We are using MS Desktop version 9.0.0.262. When the image is added to the map the colors appear washed out, almost as if there is a film on top of the image. I have a attached jpegs to demonstrate how the image should look and also how it looks when it displays incorrectly. I tried to upload the .tif file to my FTP account, but for some reason I can no longer connect. Please take a look and see what you think.
Steve
TifTest.zip (513 KB)
Hi Steve,
It seems that the “Incorrect_Display” image is translated. Any of the properties “Transparency”,“RedTranslation”,“GreenTranslation”,“BlueTranslation” will have an effect on the layer if they are set instead of the default values.
If it isn’t the cause of the issue, please contact the sales@thinkgeo.com to get a new FTP account and share your data, a sample will be better.
Peter
Hi Peter,
 I am not setting any of the properties you mentioned, just taking the defaults. I have re-activated my FTP account and uploaded one of the problem files. The name of the file is GeoTiffRasterLayer.zip. Please have a look.
 Steve
Hi Steve,
Thanks for sharing the data. It proved to be a new feature which had been available since version 9.0.198.0(Development). Please get the newest version from Product Center and have a try again.
And it wasn’t available in the Production version, because we need to do a lot of testing for it.
Any questions please let us know.
Peter
Hi Peter,
 Today I downloaded the Production build 9.0.0.268 and had a try, but the image still does not display properly. Do I need to wait for the next build?
 Steve
Hi Steve,
The new feature is not available in the Production build 9.0.0.268 now. Currently it’s only available in the Development version 9.0.198.0 or higher.
Please get the latest Development version and have a try again.
Peter
Hi Peter,
 Thanks for your response. I tested with the latest Development build and it works fine. However, we have an application that is deployed to users and we don’t want to use the Development build in that application since it is less stable than the Production build. I assume this new feature will not be available in the Production build until the release of MS 10.0 sometime in June?
 Steve
Hi Steve,
Yes, the new feature will be available after it’s stable, but It seems that this issue is caused by the alpha value.
I think there are two options:
  1. Set a dark color for the winforms.Map.BackgroundOverlay.BackgroundBrush: winforms.Map.BackgroundOverlay.BackgroundBrush = GeoBrushes.Black.
  2. Change the alpha value by other tools.
Sorry for any inconvenience.
Peter
Hi Steve,
Please try again with the latest Daily Builds version 9.0.0.277(Production) or any higher version.
Hope it helps,
Emil
Hi Emil,
Thanks very much, it works fine in 9.0.0.296.
Steve
Hi Steve,
Very glad to hear it works for you.
Peter
