Problem with postgis layer
Hello
I'm using the desktop edition 3.0 to load a postgis layer and i'm geting this error:
This method will return too many cells that might cause performance problem. Please use GetIntersectingGrid method instead.
the code is:
        Dim postgis_layer As New PostgreSqlFeatureLayer
        Dim connectString As String = "Server=128.10.10.135;User Id=postgres;Password=****;DataBase=GIS_TEST;"
        postgis_layer = New PostgreSqlFeatureLayer(connectString, "tr3992ba_p", "gid")
        postgis_layer.ZoomLevelSet.ZoomLevel01.DefaultAreaStyle = AreaStyles.Urban2
        postgis_layer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = 20
        postgis_layer.Open()
        Dim static_overlay As New LayerOverlay
        static_overlay.Layers.Add(postgis_layer)
        map.Overlays.Add(static_overlay)
        map.CurrentExtent = postgis_layer.GetBoundingBox
        map.Refresh()
I have never had this problem with previous version.
Thx
Gerion,
 Thanks for your post and welcome you to ThinkGeo MapSuite Forum!
I think you did not set the correct MapUnit, try to set the Unit to Meter or feet which depends on the data unit.
winformsMap1.MapUnit = GeographyUnit.Meter
Thank you Yale, it's working now.
Just one more question, when I try to use this
it gives me this error:
function st_extent(geometry) does not exist
I'm importing the npgsql and postgreExtension that are installed by map suite.
Thx again.
Gerion,
 Thanks for your post!
I think it seems there is some functionalities missed in your Postgre server, just like the st_extent function.
Can you try to confirm the function ST_EXTENT in your postgre server works well?Also can you check what version you are trying to use?
string versionString = WinformsMap.GetVersion();
