Problem with ThemeItem Selection
Dear Yale
As per Sample made in C Sharp for Map suite explorer, I have created ThemeItem and ThemeView Control in vb.net. I think there is something missing in code, so the event on check box change and selection of theme item not fire. Pleas help.
Private Sub SetupThemeItem(ByVal layer As Layer)Dim themeItem As New ThemeItem()
themeItem.ShapeName = layer.Name
AddHandler themeItem.ItemCheckedChanged, AddressOf themeItem_ItemCheckedChanged
AddHandler themeItem.ItemLinkClicked, AddressOf themeItem_ItemLinkClicked
AddHandler themeItem.ThemeItemClick, AddressOf themeItem_ThemeItemClick
AddHandler themeItem.ThemeItemRightClick, AddressOf themeItem_ThemeItemRightClickEnd Sub
Private Sub themeItem_ItemCheckedChanged(ByVal sender As Object, ByVal e As ShapeEventArgs)If DirectCast(winformsMap1.Overlays(0), LayerOverlay).Layers.Contains(e.ShapeName) Then
winformsMap1.Overlays(0).Lock.EnterWriteLock()
Try
DirectCast(winformsMap1.Overlays(0), LayerOverlay).Layers(e.ShapeName).IsVisible = e.IsShow
Finally
winformsMap1.Overlays(0).Lock.ExitWriteLock()
End Try
 Try
DrawImage()
Catch
End Try
End If
End Sub
But the ThemeItem_ItemCheckedChanged Event not fire. Or Please can you provide Map Suite Explorer Sample copy in Vb.net
Regrards
Sanjay
 ThemeView.Items.Add(layer.Name, themeItem)
 End Sub
Sanjay,
Thanks for your posts and questions.
I am sorry to say that it is very hard to provide the VB sample for Map Suite Explorer for now as the project is somehow huge, is it possible to provide me your sample to recreate this issue, I reviewed the code above and I did not find any problem with it.
Yale,
 I have attached my sample with ticket no 3370. Please review my code and correct is if any, so that I will able to check / uncheck the layer and selct that layer for movement up/down
 Regards
 Sanjay
Sanjay,
 I have replied to you via the ticket, please check.
Yale,
 I have Tab FeatureLayer, it shows data. I have done thematic color or this layer. So, I before implementing thematic color, I want to make copy of FeatureLayer. So the thematic color can apply on copy of FeatureLayer, and original not be disturbed.
 How to made a clone of FeatureLayer.
 Regards
 Sanjay
Sanjay,
 We need to consider using the serialization/deserialization for the feature layer, while I am sorry to say that for now not all feature layer can be serialized, following posts shows how to serialize the shape file feature layer, pls take a look if you are intested.
 gis.thinkgeo.com/Support/DiscussionForums/tabid/143/aff/21/aft/8134/afv/topic/Default.aspx
Yale,
 I don’t want to save layer permanently into my disk. I just want to make copy of feature layer for a session.
 Regards
 Sanjay
Sanjay,
 You can save all features to a InMemoryFeatureLayer, about how to add feature you can look at HowDoI samples->AddFeaturesFromAFeatureLayer sample.
James,
 I think you didn’t understand properly. I am not trying to copy a feature, although I am trying to copy a TabFileFeatureLayer, which will be treated as different object.
 If any thing more you want to clear please let me know.
 Regards
 Sanjay
Sanjay,
Thanks for your post and feedbacks.
If you want to keep this copy in memory or session, why not try to save those properties used to construct the feature layer instead, for example, try to keep the pathFileName, idColumnName, featureSchemaName instead of keeping the TabFeatureLayer, and then try to create a new TabFeatureLayer using these properties when needed. What is your opinion?
Yale,
 You mean to say to create a new TabFeatureLayer with different name, whenever required, with help of already loaded tab file. It could be one solution.
 Actually where I required a copy of TabFeatureLayer, that is different form. Initially when TabFutureLayer created that process is wriiten on Main form. Also I have to find the file name from a colletion of Tab File. Is the copy facility not availalable in API?
 What is cloneDeep?
 It is working with Layer, but not with FeatureLayer?
 Regards
 Sanjay
Sanjay,
 CloneDeep rely on serializable, however TabFeatureLayer didn’t support serializable so that you couldn’t use CloneDeep to copy it.
 I have updated the FdoExtension and make the TabFeatureLayer support it, please get the latest version 4.5.143.0 tommorrow and have a try.
James,
After download from customer portal, how I use this update. Please guide me.
In updated version, which property will be use. Please brief them.
Regards
Sanjay
Sanjay,
As your mention by using CloneDeep API:
                TabFileFeatureLayer layer = new TabFileFeatureLayer(@"..\..\SampleData\Data\HoustonMuniBdySamp_Boundary.TAB", "FID", "OGRSchema", "HoustonMuniBdySamp_Boundary", "GEOMETRY");
                layer.ZoomLevelSet.ZoomLevel01.DefaultAreaStyle = AreaStyles.CreateSimpleAreaStyle(GeoColor.FromArgb(100, GeoColor.SimpleColors.Green), GeoColor.SimpleColors.Green);
                TabFileFeatureLayer copiedLayer = layer.CloneDeep() as TabFileFeatureLayer;
James,
 How to update DLL file.
 Regards
Sanjay,
 You can find the old FdoExtension.dll on your disk, delete it and copy the new FdoExtension.dll to the same folder, or you can change the reference of your application and point to the new FdoExtension.dll.
James,
I have changed the FdoExtentio.dll (4.5.0.144 and 4.5.144.0 both Tested), but I am getting error like
Type 'MapSuiteFdoExtension.GeoFdoFeatureSource' in Assembly 'MapSuiteFdoExtension, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null' is not marked as serializable.
Actually my proceess of copy like this,
Dim Layer As FeatureLayer = winformsMap1.FindFeatureLayer(drpTable.Text.Trim)
 'drpTable.Text contains the name of TabFeatureLayer
dim copiedLayer As TabFileFeatureLayer = TryCast(Layer.CloneDeep(), TabFileFeatureLayer)
its generates error, also I have tried like below but same result
Dim
 t As TabFileFeatureLayer = TryCast(Layer, TabFileFeatureLayer)
Dim copiedLayer As TabFileFeatureLayer = t.CloneDeep
Regards
Sanjay
Sanjay,
You may find the wrong layer which type is not TabFileFeatureLayer, because I did following test, it works properly.
            Dim layer As New TabFileFeatureLayer()
            Dim copiedLayer As TabFileFeatureLayer = TryCast(layer.CloneDeep(), TabFileFeatureLayer)
James,
You are right. I am also not getting error when I have created a new TabFeatureLayer and try to use CloneDeep API in the same module.
Please try to like this.
On page load
Dim worldLayer As New TabFileFeatureLayer("D:\Desktop Working\New Folder\upw vector\vector.tab", Nothing)worldLayer.Name = "Vector"
Dim customLineStyle As Style = New AreaStyle(New GeoPen(GeoColor.SimpleColors.Black, 1))
Dim customAreaStyle As Style = New LineStyle(New GeoPen(GeoColor.SimpleColors.Black, 1))
Dim customPointStyle As Style = New PointStyle(PointSymbolType.Star, New GeoSolidBrush(GeoColor.SimpleColors.LightGreen), 10)
worldLayer.ZoomLevelSet.ZoomLevel01.CustomStyles.Add(customAreaStyle)worldLayer.ZoomLevelSet.ZoomLevel01.CustomStyles.Add(customPointStyle)worldLayer.ZoomLevelSet.ZoomLevel01.CustomStyles.Add(customLineStyle)worldLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20
Dim staticOverlay As New LayerOverlay()
staticOverlay.Layers.Add("WorldLayer", worldLayer)
WinformsMap1.Overlays.Add(staticOverlay)
Process.GetCurrentProcess().ProcessorAffinity = CType(1, System.IntPtr)
worldLayer.Open()
WinformsMap1.CurrentExtent = worldLayer.GetBoundingBox
worldLayer.Close()
WinformsMap1.Refresh()
Now click on copy button and try to use following code:
Dim
 Layer As FeatureLayer = WinformsMap1.FindFeatureLayer("WorldLayer")
Layer.Close()
Dim copiedLayer As TabFileFeatureLayer = TryCast(Layer.CloneDeep(), TabFileFeatureLayer)
We can not careate a new TabFeatureLayer (as you shown) for copy purpose, beacuse TabFeatureLayer is already created. We have to find the FeatureLayer to create copy, I tried with above code. If anything wrong with code please let me know. In other way you can try to make copy with WinForms1.FindFeatureLayer
Sanjay
WinformsMap1.MapUnit = GeographyUnit.DecimalDegree
WinformsMap1.BackgroundOverlay.BackgroundBrush = New GeoSolidBrush(GeoColor.SimpleColors.Transparent)
Now Create a Button to copy above created TabFileFeatureLayer:
I have Created Like below:
Dim Layer As FeatureLayer = WinformsMap1.FindFeatureLayer("WorldLayer")
Layer.Close()
Dim copiedLayer As TabFileFeatureLayer = TryCast(Layer.CloneDeep(), TabFileFeatureLayer)WinformsMap1.CurrentExtent =New RectangleShape(-90, 45, 90, -45)
Sanjay,
 I tested your code and I can recreate your problem, I think you need to CloneDeep TabFileFeatureLayer before calling TabFileFeatureLayer.Open(), otherwise it will throw exception, the reason is that when you call open method, it will load some unmanaged source which can’t be serialize.
 Sorry for inconvenice.
