Problems on having loaded the map shp
This one is my code and the problem is that it loads the web but I do not visualize the map
you can help me
Protected
 Sub Page_Load(ByVal sender As Object, ByVal e As System.EventArgs) Handles Me.LoadIf (Not Page.IsPostBack) Then
Map1.BackgroundFillBrush =
Map1.CurrentExtent =
Map1.MapUnit = GeographyUnit.DecimalDegree
New GeoSolidBrush(GeoColor.FromHtml("#B3C6D4"))New RectangleShape(-114.34, 75.27, 108.79, -70.23)
Dim
mapanavarra =
 mapanavarra As ShapeFileLayerNew ShapeFileLayer("c:\navarra\Navarra.shp")
mapanavarra.ZoomLevelSet.ZoomLevel01.DefaultAreaStyle = AreaStyles.GetSimpleAreaStyle(GeoColor.FromArgb(255, 243, 239, 228), GeoColor.FromArgb(255, 218, 193, 163), 1)
mapanavarra.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20
Map1.StaticLayers.Add(
"MapaNavarra", mapanavarra)
Map1.ScaleLine.Enabled =
True
Map1.PanZoomBar.Enabled =
True
Map1.MousePosition.Enabled =
True
Map1.LayerSwitcher.Enabled =
True
Map1.Overview.Enabled =
True
End
 If
End Sub
Alan,
 After rearranging your code, it works well on my machine. Could you please do the following checks to see if you can figure it out?
Step 1, run the attached code to see if it works (please change the data path in the code if you didn’t install it in the default folder)
Step2, if Step1 doesn’t work, please let me know about your machine environment, such as the operating system, the version of VS and Web Edition.
Step 3, if Step 1 works, please change to your own data. If you are still having the problem, please send the data to us and we will have a further investigation here. Just send it to support@thinkgeo.com and ask to forward to Ben.
46-VBCodeForAlan.txt (1.21 KB)
Thank you Ben, I find the solution and it was the projection. Anyhow thank you.
The code that is absent is
mapazaragoza2.FeatureSource.Projection = New Proj4Projection(23030,23030)
alan
sorry and also this line
mapazaragoza1.FeatureSource.Projection = proj4Projection
Thanks for letting me know, Alan. And we are always glad to help you for any more queries.
