Problems with google/yahoo/virtual maps
I had a simple web application wich I saved and don't touched again because it worked, wich the only thing it do is show a points layer of my own over google/virtual/yahoo maps,but now, I get two errors:
- First: I can't see my points, I only get the whole screen full of the next text :
Could not find any resources appropriate for the specified culture or the neutral culture.  Make sure "ThinkGeo.MapSuite.WebEdition.Properties.ExceptionDescription.resources" was correctly embedded or linked into assembly "WebEdition" at compile time, or that all the satellite assemblies required are loadable and fully signed.
- Second: When a change the baseLayer between google and yahoo the center of the map is moved to the upper left corner and when I change it again it goes back to its place. This isn`t very important but it's very strange.
I let you the full application, if you know what is the problem I'll heard you, because the last time I get the first error I add just one line (Map1.MapUnit = GeographyUnit.Meter ) and it worked, but now again...
Thank you all for your help
289-application.zip (6.56 KB)
290-Maps.zip (235 KB)
Miren,
 It’s a known issues that no matter what exception you have got, Web Edition will eat it and throw that “resource not embed” exception instead. We will make it right in the upcoming release (be released around 22rd this month). Sorry that we cannot do much now when you got this exception as it can be any error behind the misleading description, sorry for the inconvenience.
 We opened your application without any problem though. We opened it in XP and Vista, also change the language region from English to Germany (we used to have an issue with other language setting), it all works fine.  I am not sure why you get exception on your machine.
 We recreated the map moving issue when switching the Overlays, it seems some script is affecting GoogleMap’s position. Here we made some changes to the style of the “changeSubTypeContainer” div and it works now.
 Any queries please let me know.
