Problems with Labels
I'm trying to display feature labels with Map Suite Desktop.
My map consist in a list of shape files. I have added fixed label by a featurelayer.
I've already used the solution below succesfully in one project of mine.
Protected Function AddTestoMap(ByVal AddNewLayer As StructLayer) As Boolean
        Dim bReturn As Boolean = False
        Dim OverlayAdd As LayerOverlay = ControlNameGroup(AddNewLayer.strNomeLayerOverlay)
        Dim bitmapLayer As New InMemoryFeatureLayer()
        bitmapLayer.Name = AddNewLayer.strNomeLayer
        bitmapLayer.ZoomLevelSet.ZoomLevel01.Scale = Me._MapThinkGeo.ZoomLevelSet.ZoomLevel01.Scale
        bitmapLayer.ZoomLevelSet.ZoomLevel02.Scale = Me._MapThinkGeo.ZoomLevelSet.ZoomLevel02.Scale
        bitmapLayer.ZoomLevelSet.ZoomLevel03.Scale = Me._MapThinkGeo.ZoomLevelSet.ZoomLevel03.Scale
        bitmapLayer.ZoomLevelSet.ZoomLevel04.Scale = Me._MapThinkGeo.ZoomLevelSet.ZoomLevel04.Scale
        bitmapLayer.ZoomLevelSet.ZoomLevel05.Scale = Me._MapThinkGeo.ZoomLevelSet.ZoomLevel05.Scale
        bitmapLayer.ZoomLevelSet.ZoomLevel06.Scale = Me._MapThinkGeo.ZoomLevelSet.ZoomLevel06.Scale
        bitmapLayer.ZoomLevelSet.ZoomLevel07.Scale = Me._MapThinkGeo.ZoomLevelSet.ZoomLevel07.Scale
        bitmapLayer.ZoomLevelSet.ZoomLevel08.Scale = Me._MapThinkGeo.ZoomLevelSet.ZoomLevel08.Scale
        bitmapLayer.ZoomLevelSet.ZoomLevel09.Scale = Me._MapThinkGeo.ZoomLevelSet.ZoomLevel09.Scale
        bitmapLayer.ZoomLevelSet.ZoomLevel10.Scale = Me._MapThinkGeo.ZoomLevelSet.ZoomLevel10.Scale
        bitmapLayer.ZoomLevelSet.ZoomLevel11.Scale = Me._MapThinkGeo.ZoomLevelSet.ZoomLevel11.Scale
        bitmapLayer.ZoomLevelSet.ZoomLevel12.Scale = Me._MapThinkGeo.ZoomLevelSet.ZoomLevel12.Scale
        bitmapLayer.ZoomLevelSet.ZoomLevel13.Scale = Me._MapThinkGeo.ZoomLevelSet.ZoomLevel13.Scale
        bitmapLayer.ZoomLevelSet.ZoomLevel14.Scale = Me._MapThinkGeo.ZoomLevelSet.ZoomLevel14.Scale
        bitmapLayer.ZoomLevelSet.ZoomLevel15.Scale = Me._MapThinkGeo.ZoomLevelSet.ZoomLevel15.Scale
        bitmapLayer.ZoomLevelSet.ZoomLevel16.Scale = Me._MapThinkGeo.ZoomLevelSet.ZoomLevel16.Scale
        bitmapLayer.ZoomLevelSet.ZoomLevel17.Scale = Me._MapThinkGeo.ZoomLevelSet.ZoomLevel17.Scale
        bitmapLayer.ZoomLevelSet.ZoomLevel18.Scale = Me._MapThinkGeo.ZoomLevelSet.ZoomLevel18.Scale
        bitmapLayer.ZoomLevelSet.ZoomLevel19.Scale = Me._MapThinkGeo.ZoomLevelSet.ZoomLevel19.Scale
        bitmapLayer.ZoomLevelSet.ZoomLevel20.Scale = Me._MapThinkGeo.ZoomLevelSet.ZoomLevel20.Scale
        bitmapLayer.Open()
        bitmapLayer.Columns.Add(New FeatureSourceColumn(AddNewLayer.strNomeLayer))
        bitmapLayer.Close()
        Dim ptPosition As New PointShape(AddNewLayer.dblX, AddNewLayer.dblY)
        Dim testFeature As Feature = New Feature(ptPosition)
        testFeature.ColumnValues.Add(AddNewLayer.strNomeLayer, AddNewLayer.strTestoWrite)
        bitmapLayer.InternalFeatures.Add(testFeature)
        Select Case AddNewLayer.enCodiceStile
            Case MapStyle.TestoOrdineNP
                bitmapLayer.ZoomLevelSet.ZoomLevel15.DefaultTextStyle = TextStyles.CreateMaskTextStyle(AddNewLayer.strNomeLayer, "Arial", 9, DrawingFontStyles.Bold, GeoColor.StandardColors.Black, New GeoColor(255, 255, 255))
                bitmapLayer.ZoomLevelSet.ZoomLevel15.DefaultTextStyle.BestPlacement = False
                bitmapLayer.ZoomLevelSet.ZoomLevel15.DefaultTextStyle.OverlappingRule = LabelOverlappingRule.AllowOverlapping
                bitmapLayer.ZoomLevelSet.ZoomLevel15.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20
                bitmapLayer.ZoomLevelSet.ZoomLevel15.DefaultPointStyle = PointStyles.CreateSimpleCircleStyle(GeoColor.StandardColors.White, 6, GeoColor.SimpleColors.Black, 1)
                bitmapLayer.ZoomLevelSet.ZoomLevel15.DefaultTextStyle.PointPlacement = PointPlacement.CenterRight
                bitmapLayer.ZoomLevelSet.ZoomLevel15.DefaultTextStyle.XOffsetInPixel = 5
                      Case Else
                bitmapLayer.ZoomLevelSet.ZoomLevel01.DefaultTextStyle = TextStyles.State1(AddNewLayer.strNomeLayer)
                bitmapLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20
        End Select
        Try
            '-- Aggiungo il layer al gruppo
            OverlayAdd.Lock.EnterWriteLock()
            OverlayAdd.Layers.Add(bitmapLayer.Name, bitmapLayer)
            If AddNewLayer.bAddTopList Then
                OverlayAdd.Layers.MoveToTop(OverlayAdd.Layers.Count - 1)
            End If
            bReturn = True
        Catch ex As Exception
        Finally
            OverlayAdd.Lock.ExitWriteLock()
        End Try
        Return bReturn
    End Function
Me._MapThinkGeo is the map component.
StructLayer is a temporary structure for store data.
Now I have to use the same solution in another project.
The only thing that has changed is the scale of shapes files.
Everything works well but I can't see text labels on my map. On the other project, the same code works well and I see everything correctly.
John
John,
Thanks for your post,
According to your description I think your problem is from the scale of zoomlevel, as you mentioned the only thing that has changed is the scale of shapes file, so it caused the text labels cannot be displayed correctly. Obviously, you set the incorrect scale for zoomlevels. For the scale of zoomlevels you have to set them as a rule: Each zoom level is half in scale of the previous one. Please check the attachment for understanding it fully, also you can refer the sample code to your own application for setting the scale of zoomlevels. Also because the limitation issue I didn't attach the austinstreets.shp file, please reference it before you run the sample.
Scott,
CustomZoomLevels.zip (29.7 KB)
 Ok,
I've changed my code: now I set every zoom level according with your rules.
MapThinkGeo.MapUnit = GeographyUnit.Feet
MapThinkGeo.BackgroundOverlay.BackgroundBrush = New GeoSolidBrush(GeoColor.GeographicColors.DeepOcean)
GetCustomZoomLevelSet(MapThinkGeo.ZoomLevelSet, 50)
 Public Function GetCustomZoomLevelSet(ByRef zSet As ZoomLevelSet, ByVal initialScale As Double) As Boolean
        zSet.ZoomLevel01.Scale = initialScale
        zSet.ZoomLevel02.Scale = initialScale / 2
        zSet.ZoomLevel03.Scale = initialScale / 4
        zSet.ZoomLevel04.Scale = initialScale / 8
        zSet.ZoomLevel05.Scale = initialScale / 16
        zSet.ZoomLevel06.Scale = initialScale / 32
        zSet.ZoomLevel07.Scale = initialScale / 64
        zSet.ZoomLevel08.Scale = initialScale / 128
        zSet.ZoomLevel09.Scale = initialScale / 256
        zSet.ZoomLevel10.Scale = initialScale / 512
        zSet.ZoomLevel11.Scale = initialScale / 1024
        zSet.ZoomLevel12.Scale = initialScale / 2048
        zSet.ZoomLevel13.Scale = initialScale / 4096
        zSet.ZoomLevel14.Scale = initialScale / 8192
        zSet.ZoomLevel15.Scale = initialScale / 16384
        zSet.ZoomLevel16.Scale = initialScale / 32768
        zSet.ZoomLevel17.Scale = initialScale / 65536
        zSet.ZoomLevel18.Scale = initialScale / 131072
        zSet.ZoomLevel19.Scale = initialScale / 262144
        zSet.ZoomLevel20.Scale = initialScale / 524288
        Return True
    End Function
Now labels appears but I still have problems.
I'm trying to hide and to apply different styles to my layers based on zoom levels.
When I create ShapeFileFeatureLayer or InMemoryFeatureLayer I set style in this manner:
Select Case enCodiceStile
            Case MapStyle.Lago
                AddLayer.ZoomLevelSet.ZoomLevel11.DefaultAreaStyle = AreaStyles.Water1
                AddLayer.ZoomLevelSet.ZoomLevel11.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20
I expect that this featurelayer/shapelayer is hidden until zoom level 10 and visible from level 11 to 20 with Water1 style. Instead zoomlevel is always visible.
Jonathan,
 Can you provide us a simple sample so that we can reproduce this problem correctly? Currently according to our tests, if I set the area style from zoomlevel11 to zoomlevel20, the shape file is hidden until zoom level 10 and visible from zoomlevel11 to 20. So I have a question to ask you, did you set the minimum scale and maximum scale values? If you set, what are the values? If it is possible please give us a simple sample to reproduce it and resolve your problem correctly.
 Scott,
I’ve to build the sample you required.
 Meanwhile can you tell me why we have ZoomLevelSet property inThinkGeo.MapSuite.DesktopEdition.WinformsMap and also in ThinkGeo.MapSuite.Core.FeatureLayer?
 I’ve set Scale property on WinformsMap.ZoomLevelSet.
 Do I have to set Scale on every FeatureLayer.ZoomLevelSet?
I forgot to answer your question.
 I’ve set minimum and maximum scale in this manner:
 MapThinkGeo.MinimumScale = MapThinkGeo.ZoomLevelSet.ZoomLevel20.Scale
 MapThinkGeo.MaximumScale = MapThinkGeo.ZoomLevelSet.ZoomLevel01.Scale
 John
Jonathan,
I do not think you need to set scale for each feature layer as it will use the customized zoomlevel set when you set it to the map control that will also indicate why we need to set the property of ZoomLevelSet.
Any more questions or concerns please feel free to let me know.
