Problems with the "Generate EMF using GraphicsGeoCanvas" sample [bug?]
For our application we require the ability to include high quality maps in our printed reports. The sample to generate a metafile (wiki.thinkgeo.com/wiki/File:...120911.zip) seemed very promising in this regard.
However, I am having trouble limiting the extent of the map.
This is my code to generate a metafile, based on a limiting rectangle defined in the "mapinfo" object (where the scale, center point and width/height of the final map is defined):
    public void CopyMapToMetafile(string filename) {
      GraphicsGeoCanvas graphicGeoCanvas = new GraphicsGeoCanvas();
      Graphics graphic;
      Metafile metaFile;
      RectangleShape frame;
      int W_pxl, H_pxl, scale;
      double wrld_W2, wrld_H2; // Half-width and half-height of selected rectangle
      // Calculate scale and width/height of selected rectangle (in _meter_)
      scale = mapinfo.mapScale;                   // mapScale  is no. of centimeters (world) per centimeter (map)
      wrld_W2 = mapinfo.mapWidth*scale  / 2000.0; // mapWidth  is given in millimeter
      wrld_H2 = mapinfo.mapHeight*scale / 2000.0; // mapHeight is given in millimeter
      frame = new RectangleShape(mapinfo.centerE - wrld_W2, mapinfo.centerN + wrld_H2,
                                 mapinfo.centerE + wrld_W2, mapinfo.centerN - wrld_H2);
      // Calculate size of image, assuming 300 DPI
      W_pxl = (int)Math.Round(300.0 * mapinfo.mapWidth  / 25.4); // mapWidth  is given in millimeter
      H_pxl = (int)Math.Round(300.0 * mapinfo.mapHeight / 25.4); // mapHeight is given in millimeter
      // Create metafile, and an associated GraphicGeoCanvas
      metaFile = new Metafile(filename, Graphics.FromImage(new Bitmap(1, 1)).GetHdc());
      graphic = Graphics.FromImage(metaFile);
      // Draw each layer to the canvas
      graphicGeoCanvas.BeginDrawing(graphic, W_pxl, H_pxl, frame, GeographyUnit.Meter);
      foreach (LayerOverlay lovl in map.Overlays) {
        foreach (FeatureLayer lay in lovl.Layers) {
          lay.Open();
          lay.Draw(graphicGeoCanvas, new System.Collections.ObjectModel.Collection<SimpleCandidate>());
          lay.Close();
      graphicGeoCanvas.EndDrawing();
      metaFile.Dispose();
The resulting metafile looks great if, and only if, the limiting rectangle is large enough to include the full extent of all layers. A smaller rectangle results in something like this.
The problem seems to be caused by the GraphicsGeoCanvas not clipping polygons, lines and points to the given rectangle (given as the parameter "frame" in the .BeginDrawing() method).
I have no problems limiting the extent if I draw to a bitmap, but then the size of each map makes the final report file very large.
I also have the option to use the PdfGeoCanvas, which also lets me limit the extent without problems. However, this option requires an additional step to convert the PDF to a format which can be used in Microsoft Word (like EMF or EPS).
Thus, the option to generate EMF directly would be the best, if I could only get it to work...
Any suggestions?
Hi Rolf,
Set the clipping area will solve the problem,  add the following code before drawing,
canvas.EnableCliping = true;
canvas.ClipingArea = frame;
Edgar
Thanks Edgar!
Works like a charm!
Rolf Tore
You’re welcome Rolf, if you have any questions please let us know.
 Edgar
Hi, Rolf Tore.
Thanks for your nice sharing. I wonder have you ever worked it out? I have a question for you. Do you have any experience about pdf to image conversion? I want to look for a fine pdf to png converter whose way of processing is simple and fast. Any suggetsion will be appreciated. Thanks in advance.
Best regards,
Pan
Hi Pan,
 We hadn’t used any utility for pdf to png, so we don’t have any suggestion on this, but when I Google it, I found it looks many software support it. I think you can tried to download some of them and have a test.
